Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 07-11-2011, 05:55 AM
Yardpilot Yardpilot is offline
The Sable Saga Continues.
1987 Sable 3.0. I'm learning a lot with this car. It had troubles. Step by step, inch by inch, I have figured them out. Many parts have been replaced, rebuilt and/or repaired. At this point it runs slightly rough, the tach occasionally hangs at 1700-1800, it shows a code 89 (torque converter lockup), it is down on power and is only getting 11 mpg. It got 22-24 before. Idle is high, but the code says it is out of range low. It shows a knock on the code reader, but it is not equipped with a knock sensor. It used to show an EGR fault even though there is no EGR valve, but that's gone now. Any thoughts on how to proceed? Temp sender, map sensor, o2 sensor, TPS, IAC, radiator, upper manifold gasket, PCV valve all new.
2000 Trooper, The Oil Saga Continues LEM Trooper | SLX | Bighorn | Wizard 10 08-02-2006 11:59 PM
Ahhhh And the saga continues Hunter1 Blazer 2 12-30-2005 12:07 PM
the saga continues... sooner1 Suburban 5 09-17-2005 11:15 AM
and the saga continues Auror_AH Aurora 14 05-10-2004 08:58 AM
The Penguin saga continues.. Ricochet COMPLETELY off-topic 19 02-25-2004 03:53 PM
