Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 07-10-2011, 12:23 PM
jklatik jklatik is offline
89 Beretta 2.8 fuel injector ohms?
Hey all, it’s me again. after thinking i fixed the problem it still dies after getting to operating temp. So I decided to check the fuel injector ohms. Injectors 1, 3 and 6 are reading 12.4 ohms and 2,4 and 5 read 6.5, 7.3 and 8.9. Would this cause it to die after getting to operating temp. i took the reading warm and cold. When warm the only injector to maintain a 12.4 reading was #6 the rest were between 6.4 and 8 ohms. This is getting old! Also the wire harness seems to be hard and brittle, with one plug spliced, so that i will replace since the plenum is off. Thanks for the help.
Old 07-10-2011, 02:07 PM
jdl jdl is offline
Re: 89 Beretta 2.8 fuel injector ohms?
How long since a tune-up? Any applicable trouble codes? Replace injectors. You can do amp test, injector ground at pcm, key on. Should not be more than .75amp.
fuel injector cleaner RidingOnRailz Engineering/ Technical 8 07-04-2011 07:46 PM
Trying to find the Fuel Injector CyborgGold Celebrity 7 06-11-2011 07:49 AM
help! fuel injector problem Suzannes Caravan | Voyager 9 11-07-2009 02:06 PM
1988 Beretta 2.8 wont start?? ndoerr Beretta 2 01-24-2007 05:23 PM
1997 2.2 litre fuel injectors 231turbo S-10 0 07-20-2004 09:00 PM
