Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 07-11-2011, 06:11 AM   #1
jkohman1
jkohman1's Avatar
tapping sound from clutch\transmission
I have a 98 mustang 3.8l just had the clutch replaced about 3000 miles ago because the throwout bearing went bad. I got a f1 stage 1 clutch kit from ebay (the clutch kit contained a seco pressure plate with a rabco clutch disk, and a timken TOB, not sure who made the pilot bearing). but anyway when i start the car and let it idle i hear like a tapping noise coming from the tranny area, about every 2-3 seconds. It doesnt go away whether the clutch is disengaged or not and doesnt get any faster if i rev it up, seems to stop after driving for awhile tho. It didnt do it right away after replacing the clutch but started after the break in period(700 miles according to the manufacturer). Everything works fine just kinda annoying and not sure if i should be worried about it or not. Any thoughts would be appreciated. oh and also my cable quadrant is bad (clutch pedal rattles sometimes driving at low rpms) not sure if that could be causing it or not. Thanks
jkohman1 is offline   Reply With Quote
Popping sounds from front end itzaboy Cavalier Problem Diagnosis 1 07-13-2011 06:29 AM
Tapping sound from motor the_game_rock Neon | Plymouth Neon 10 03-30-2006 07:12 PM
Tapping sound coming from..... 99trooper01 Trooper | SLX | Bighorn | Wizard 1 12-11-2005 01:05 PM
Tapping Sound from Engine pblakey2003 Blazer 8 09-08-2005 09:29 PM
Tapping sound from 4.3L engine in cold weather Jimba61 Jimmy 1 12-06-2004 09:47 AM
