Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 04-23-2011, 09:52 AM   #1
jayjp200
Windstar front end - Single clunk at start up
Hello,
I own a 98 Ford Windstar 3.8 lit and has 200,000 kms on it.
I have been experiencing a single clunk noise in the front end. It only happens at the startup if the car was sitting for few hours.
I cannot repeat the same if I turned off the van and restarted again. It has to sit for 3-4 hours for the clunk to repeat.
I have replaced the following and it did not help.
Outer tie rods, Engine mounts - Front and back, Strut bearings, Stabilizer links, Subframe bushings, Sway bar and bushings (Metal sleeve welds are fine), Lower control arms, Front wheel bearings.
I am tired of this clunk now. It happens only once and is loud.
Please help.
Thanks.
Jay
jayjp200 is offline   Reply With Quote
Old 04-23-2011, 10:45 AM   #2
12Ounce
Re: Windstar front end - Single clunk at start up
Is the vehicle changing directions at start-up? Are you parking stopping forward, but starting up in reverse for example? If so, the brakes may be your noise maker. Do you always use the parking brake? (You should.)
12Ounce is offline   Reply With Quote
Old 04-23-2011, 02:07 PM   #3
jayjp200
I always park stopping forward and Yes, I am changing the direction when backing out. The clunk noise comes as soon as the steering goes 10 o' clock position. It only happens once.
I always use my parking brakes. The clunk seems to be from fron passenger side.
Please reply.
Thanks
Old 04-23-2011, 03:03 PM   #4
12Ounce
Originally Posted by jayjp200 View Post
..... The clunk noise comes as soon as the steering goes 10 o' clock position..........
Please reply.
Thanks
Ah ... another clue! I don't take brakes off the list ... but now put the steering system on top of the list. Something is loose ... either from wear or improperly assembly. Be sure to re-inspect the rack mounting bolts, the links, inner and outer tie-ends .... and all around the top of the struts; in particular, the shock-top anchorage. Check lower control arms. Check motor mounts and sub-frame mounts.
Old 04-23-2011, 03:15 PM   #5
jayjp200
I will check the rack mounting bolts today evening.
Are you suggesting the rear brakes or the front ones...and what to be looked in particular for brakes.
The subframe bolts are good as I have replaced the 4 bushings and new bolts in February this year and the allignment was done in March after I changed the outer tie rods.
I have just replaced the motor mounts yesterday.
Thank you for the suggestions. I will check the rack bolts today and post my findings.
Regards,
Jay
Old 04-23-2011, 08:14 PM   #6
12Ounce
Be sure to check the strut "tops"....
If it is the brakes, its because they need prescribe lubrication. Drum brakes are probably more of a problem than discs.
Old 04-24-2011, 10:34 AM   #7
jayjp200
I have just finished checking the rack mount bolts and they did not even move. So it is not the rack being loose.
I will now check the strut tops.
Thanks
Old 04-24-2011, 12:23 PM   #8
12Ounce
... about those rack bolts. They are splined, so you will not be able to turn them. Its the nuts beneath that do the fastening ... over 100 ft lbs, IIRC.
Good luck!
Old 04-24-2011, 12:25 PM   #9
12Ounce
... also check the lower control arms. Could be a worn pivot knuckle or rubber bushings. Loose bolts/nuts.
Old 04-25-2011, 12:44 PM   #10
jayjp200
I have checked the strut tops and the lower control arm. All is tight and nothing moved.
I also replaced the rear brakes.
The clunks is still present.
Thanks
Old 04-25-2011, 09:41 PM   #11
12Ounce
Wow, you have a mystery indeed. Any chance you could have an associate do the first few feet of driving some morning ... while you hang over a fender with your head underhood, or near a wheel ... just to get a better idea?
Old 05-30-2011, 03:18 PM   #12
jayjp200
Finally the mystery is resolved. I have replaced both sides CV joint assemblies and also the center Hubs.
The clunk is gone.
The noise was either from inner cv joint on passenger side or from the hub as the brake rotor might be slipping between the hub and wheel.
Anyways my death star is noise free and is Windstar again.
Regards,
Jay
Old 05-30-2011, 07:35 PM   #13
12Ounce
Good ... thanks for feedback!
02 Town and Country Lmt, FWD - Clunking from front end and power door problems confused81 Caravan | Voyager 12 08-06-2010 11:19 PM
Creaking Noise At Front-End el ratfink Pacifica 2 12-05-2009 12:57 PM
Front end noise Bob Moore Dakota 5 07-25-2009 05:40 PM
Clunk in Front End 97 Blazer Massguy Problem Diagnosis 3 07-05-2009 09:02 AM
Front End Metallic Clunking amesjm0431 Grand Prix 2 06-17-2009 10:17 PM
