Go Back   Automotive Forums .com Car Chat > Toyota > Avalon/Pronard
Old 06-23-2011, 04:15 PM   #1
RexG
2000-2004 Avalon O2 Sensor Replacement Guide
So I've read a lot of posts on how to change O2 sensor and here's my review after just replacing mine.
My check engine light came on again so I took it to my local Advanced Auto Parts Store to get free code check.
I figured it was just the same old tighten gas cap code I seem to get 1 to 2 times/year and I would just need to reset by disconnecting the battery.
Well it ended up saying I needed to replace bank 1 O2 sensor (which after reading some other posts is the one nearest to firewall) the harder one to get to.
I was going to just get the O2 sensor at Advanced but after doing some research I found a better deal at RockAuto where I was able to get a Denzo O2 for $101.62 and that included shipping.
When I first found it I thought it would be really hard to get out but follow my method and it should be pretty easy.
First thing I did was reach down and sprayed it down with PB Blaster several days before I actually received the part and did the job so it would give it time to really work in.
The morning after I got the part, I sprayed some more PB Blaster on it then reached down and back up from the top right side and was able to unplug fairly easy.
Next I found that 7/8in boxed end wrench fit on it nicely. so I threaded the wire through the boxed end then proceeded to lean on it as hard as I could but it didn't budge. So I went back online and read a post by someone saying to run the engine for 5 minutes then try again. Well I have to say that was some great advice as it came loose so easy I almost hurt myself...lol. I was able to unscrew by hand the rest of the way...pretty cool.
Once I got it out I just had to screw in and tighten the new part and plug it in.
The code should clear itself after you start the car.
Another quick note: They say to put never seize on the threads but the part I got already had it applied.
Reply to thread if you have any questions.
RexG
RexG is offline   Reply With Quote
The Following User Says Thank You to RexG For This Useful Post:
Brian R. (07-04-2011)
96 Civic HX o2 Sensor Replacement.... shvd98z24 '96-'00 Civic 3 03-30-2009 09:49 PM
Tags
avalon|o2 , engine , sensor , sensors|check
