Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 05-28-2011, 06:30 PM   #1
lazeit
99 Winy With a Taping Noise From Heating Cooling System
My Winny started a moderately loud tapping noise inside the vehicle that sounds as if it was coming from write behind the radio or a bit to the passenger side. It’s not the engine or trany and sounds like something in the heating and cooling system. The tap is very rhythmic. Thoughts?
lazeit is offline   Reply With Quote
Old 05-28-2011, 08:32 PM   #2
12Ounce
Re: 99 Winy With a Taping Noise From Heating Cooling System
Search for "blend door operator"
12Ounce is offline   Reply With Quote
Old 05-28-2011, 09:50 PM   #3
wiswind
Blend door actuator is the FIRST thing that comes to mind.
This is a door that moves back and forth to control how much HOT air is to be blended with the air entering the passenger compartment.
The heater core is always hot (at least when the motor is warm).
The interior temperature is controled by the position of the blend door.
When you adjust the temperature, a electric motor drives a gear that moves the blend door.
The clicking is likely the gear teeth clicking over each other.
This is a VERY common failure, which is why a search on "blend door" will get you a LOT of posts.
I was very lucky.....and never had a problem with this.
The blend door, which is driven by a electric motor is NOT to be confused with the diverter doors, which are driven by vaccum solenoids.
The diverter doors control where the air goes, such as the defrost, floor or vent.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
wiswind is offline   Reply With Quote
cooling system back pressure, heater not working BrandonMurray Grand AM 4 04-27-2010 09:25 AM
1995 325i Cooling system overheating troubleshooting kennethwperry 3 Series 0 09-20-2009 08:32 PM
Rear Heating/Cooling System Mike_EX Montana/Montana SV6 5 07-19-2006 08:51 PM
Whistle/buzz in heating/cooling system jaws38 Crown Victoria 0 08-18-2005 07:57 PM
Sentra Vent Heat/Cool System mdubin Sentra | 200SX (USDM FWD) 1 12-19-2001 11:03 AM
