Old 05-01-2011, 10:37 AM   #1
goser
4L60E Automatic Transmission Interchangeability
2001 Blazer ZR2 4x4; I haven't given up on the manual swap, but I'd like to throw an auto in just to get it moving for the near future. Can't seem to find a consensus on what transmissions are compatible... Wrecker says only 2001 from Jimmy 4x4/Blazer 4x4/Astro AWD/Safari AWD will work, but I've heard others say any 2000+ from a 4x4 will work, and even 98/99 will work. Any advice would be appreciated, as I could pick one up much cheaper than the wreckers if I can guarantee compatibility.
'01 Chevy Blazer ZR2 4x4 VIN=W
'80 Yamaha XJ650 Maxim
'08 Jeep Patriot 2.4L
goser is offline   Reply With Quote
Old 05-01-2011, 05:05 PM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: 4L60E Automatic Transmission Interchangeability
The salvage yard interchange book knows best.
It says what is direct fit witrh no change.
It Also tells if anything else will or what has to be changed to get it to work.
MT
Old 05-11-2011, 09:31 PM   #3
goser
Thanks again for the reply MT.
Unfortunately my local wreckers haven't been overly helpful with me. A friendly fellow from the local classifieds has told me that a 2WD tranny could be made compatible by swapping the tail shaft... can anyone confirm or deny this? I can't afford to spend the cash right now on an experiment. Thanks!
Old 05-12-2011, 06:55 AM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
Ye it can be done.
But you have to take the transmission completley apart to do it.
You might as well fix your old one or get the right transmission for it.
MT
Water in 4L60E automatic transmission do i need to rebuild transmission Ryan Hermann Problem Diagnosis 3 04-07-2010 11:32 PM
1995 Impala SS - Transmission Shifting Hard LT1Silverhawk Impala | Impala SS 2 06-01-2009 08:49 PM
Sun Gear Shell Failure GM 4L60E Automatic Transmission kyeagle General Discussion 8 01-23-2006 01:23 PM
Sun Gear Failure GM 4L60E Automatic Transmission kyeagle General Discussion 2 04-03-2004 02:56 PM
4L60E automatic transmission vicandted Yukon 0 01-02-2004 04:10 PM
