Old 05-28-2003, 10:24 AM   #1
goldtop33
Question Oil change Question
Just wondering - whats the best oil to use for an oil change?
Thanks!
goldtop33 is offline   Reply With Quote
Old 05-28-2003, 10:28 AM   #2
AirAllen01
AirAllen01's Avatar
Send a message via Yahoo to AirAllen01
Castrol, Vavoline, or Penzoil 10w-30 and you should be good.
AirAllen01 is offline   Reply With Quote
Old 05-28-2003, 10:42 AM   #3
goldtop33
Thanks...my friends was telling me mobil was the best and i was just wondering what people on here thought...
Old 05-28-2003, 01:34 PM   #4
OffroadX
Send a message via AIM to OffroadX
Any oil will do really, the question is to use regular or synthetic.
However, if you go with regular, I've seen a lot that indicate that Valvoline High-Mileage is about the best there is. Best grade of base stock and a great additive package. Nothing at all wrong with using it in a new engine.
Brent
OffroadX is offline   Reply With Quote
Old 05-28-2003, 01:43 PM   #5
goldtop33
What is the difference between regular and synthetic - and which is better for the Xterra?
Old 05-28-2003, 03:19 PM   #6
OffroadX
Synthetic is better, but costs 2-5 times as much. However, you can run extended oil change intervals (10,000 miles isn't a stretch) and recoup the cost that way.
Synthetic flows better in cold weather and is generally superior to regular oil in every way including lubrication and high-temperature stability. Then again, plenty of engines go 200,000 miles or more with plain oil changed every 3000 miles.
Brent
Old 05-29-2003, 09:18 AM   #7
hobbes69
hobbes69's Avatar
I know its overkill, but I change mine every 5,000 miles with Mobil Full Synthetic and a Mobil "High Efficiency" filter. I'd probaby go longer but it does come out pretty dark at 5,000. I buy the oil by the case from Costco which offsets the cost of the oil change a bit. The main reason for choosing 5000 miles is its real easy to remember, I don't have to write anything down!
Richard
hobbes69 is offline   Reply With Quote
Old 05-29-2003, 09:59 AM   #8
OffroadX
I change my Mobil 1 at 5000 too. I have noticed that Mobil 1 is darker than most even when new, which may account for it being so dark at 5000. Either way, it's not like it's expensive, I buy a gallon for $16 every couple of months or so, gasp!
Brent
Old 05-29-2003, 10:36 AM   #9
RedX
RedX's Avatar
Send a message via AIM to RedX
Yep....I've been using Mobil 1----10W-30 for some time now with the changing intervals along the lines of the others here. I have also noticed it being pretty dark at changes, but not overly so.
Seems like, even at the higher price, a good investment (perhaps) in the longevity of an engine I plan on driving for a while.
Brad & RedX
Senior member of ENCXC
2000 Aztec Red Xterra XE 4x4 3 Pk.
RedX is offline   Reply With Quote
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 09:39 PM
