Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 04-06-2011, 11:15 AM   #1
gtp3.8
Bad Radio or A Voltage Issue?
Hello I am new to the Mustang forums. I have been reading over some of the old posts and I feel like I maybe I have narrowed this down to one of the two problems. I have a 1991 LX with the 5.0 5 speed. It does have a small cam and other supporting mod incase that would be of any revelance to the issue. This problem seems to happen more at night than any other time. Whae I come to a red light or stop sign and start to take off my radio cuts out but when it comes back on all of the settings are still in place Base Treb ect. My volt meter gets about a mark and a half from the bottom red mark but ones I get to going it will pick back up. I just monday put a new altinator (factory size) on it and same problem thought it does have a higher charge now while running. Last night when I parked in the drive way and let it idle the radio would play but when I would flip from low beam to high beam it would cut out. I know that the alt pulley is factory size but im not sure about the crank and water pulleys. Im going to check those when I get off. Does this sound like a charging problem or a radio or wiring problem? Thanks for any help or advice.
Justin
gtp3.8 is offline   Reply With Quote
Old 04-06-2011, 06:41 PM   #2
HiFlow5 0
Stanger
HiFlow5 0's Avatar
Send a message via AIM to HiFlow5 0
Re: Bad Radio or A Voltage Issue?
Do you have an aftermarket radio or is this a stock one? I'm going out on a limb here and going to say it sounds like a faulty wiring job of some sort.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
HiFlow5 0 is offline   Reply With Quote
The Following User Says Thank You to HiFlow5 0 For This Useful Post:
gtp3.8 (04-08-2011)
Radio Issues 98redvenge Avenger 0 08-30-2009 03:03 AM
voltage issue on 89 wrangler. greyjeep Wrangler 0 08-23-2005 03:48 AM
Got a voltage issue... SpyderGuy97 Off-Topic 1 03-20-2005 11:10 PM
Voltage issues sideshowrich Let's get Technical! 5 12-05-2004 08:39 AM
radio voltage mahsdarf Accord/TSX/Accord Hybrid 1 09-05-2003 03:15 AM
