Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 02-11-2011, 07:10 PM   #1
olopezm
olopezm's Avatar
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Torque Strut Mounts
Hello guys,
Just a quick question:
The bushing on one of my torque strut mounts has gone bad, the metallic piece has separated from the rubber and it's causing a small engine vibration when I accelerate from idle. Money is tight and I would like to go the cheapest way if possible so I went to the junkyard today and I could only find both mounts for the 3100 engine,
Is there any chance to swap the 3800 with 3100 engine mounts?. I compared both and the only difference (as you should already know) is the 4 bolts at the radiator side against 3 bolts for the 3100, size is the same so I know it fits, but will I have any other problem?
Thanks in advance,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
olopezm is offline   Reply With Quote
Old 02-12-2011, 07:32 PM   #2
tblake
In God We Trust
tblake's Avatar
Re: Torque Strut Mounts
Oscar, you should be able to remove the rubber from inside the 3100 mount and put it in the 3800 mount. (if I am thinking of the right mount you are talking about).
Refir to this article about engine mount stiffening. Might give you an idea of how to get the rubber bushings out.
http://www.zzperformance.com/grand_p...les1.php?id=45
-2000 Grand Prix GTP 170,000mi (daily driver)
-2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal)
-1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix])
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
"I'll Keep my Guns, Freedom, and Money. You can Keep the Change!"
----->>>>> Did You Know? <<<<<-----
tblake is offline   Reply With Quote
Old 02-12-2011, 08:05 PM   #3
olopezm
olopezm's Avatar
Thanks Tim, it seems we are talking about the same mounts, the ones that hold the dogbones onto the body right at top of the radiator.
Unfortunately the link you provided no longer works, I get a 404 Not found error, I guess I'll search google for "engine mount stiffering" just to see if I can find anything similar; do you know about any other source for the same article?
Regards,
Oscar.
Old 02-12-2011, 08:20 PM   #4
olopezm
olopezm's Avatar
I forgot to mention that I did try to swap the bushings but they are real hard to get out.
Old 02-12-2011, 08:59 PM   #5
tblake
In God We Trust
tblake's Avatar
Thats all the link was... instructions on how to get the bushings out using a screwdriver, wd40, and an easy out. I will see if I can find another source, but sounds like your on the right track.
Old 02-12-2011, 11:44 PM   #6
olopezm
olopezm's Avatar
Thanks, I'll keep trying.
If I can find anything about how to remove the bushings I'll post it here for future reference.
Regards,
Oscar.
Rear suspension sound: Strut mounts? olopezm Grand Prix 27 12-29-2010 12:51 PM
Struts mount kit alignment and torque mount cavalieronyc Cavalier Problem Diagnosis 0 04-25-2010 10:46 PM
Replacing the struts & strut mounts Jmalbright Alero 8 03-15-2010 11:21 AM
Replaced motor mount, torque struts, and trans mount on 93' Euro, still have noise :( kehi66 Lumina 0 02-04-2007 04:41 PM
Strut mounts and Struts Tech_n Grand Prix 5 04-11-2005 07:01 AM
