Go Back   Automotive Forums .com Car Chat > Honda > Civic | CRX > '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
Old 06-06-2002, 11:35 PM   #1
markpa
markpa's Avatar
Just installed my Angel eyes projectors (j.fuggi Please Read)
Like the subject says, they work like there suppose to but i have a little dillema, when i opened the box today i had the two projectors and a wiring harness, so i say looks simple enough so i install the lights and wire up the harness, turn the switch on and nothing lights dont work, so then i decide to hook up the light without using the wiring harness and bang the work great, so im wondering was i given a wiring harness by mistake???Or is it meant to be installed, and if so how???
Oh i got the new ones that just came out there pure black heres a pick.
markpa is offline   Reply With Quote
Old 06-07-2002, 12:24 AM   #2
onesojourner
onesojourner's Avatar
Send a message via AIM to onesojourner
dang those are sweet how much did you pay? what bulbs do they take?
don't like my post
The things you own end up owning you-Tyler Durden
videos
onesojourner is offline   Reply With Quote
Old 06-07-2002, 01:58 AM   #3
Rice-Rocketeer
The wiring harness is neccesary to convert the system from a 1 H4 bulb system to a dual H1, H3 bulb system. Do the high beams work ok?
Lookin at my gucci, it's about that time...
Rice-Rocketeer is offline   Reply With Quote
Old 06-07-2002, 06:33 AM   #4
markpa
markpa's Avatar
No they dont work the way there suppose too???Im totally confused...the wiring harness has two 12v relays and 2 fuses and a couple of connectors if that helps????Please help
Old 06-07-2002, 09:36 AM   #5
Whtehnda93DXSdn
Send a message via AIM to Whtehnda93DXSdn
well sorry that you are having problems w/ them but they do look really sweet that's for sure....
Thanks for sharing the info and pic...:frog:
another good honda site:
www.civicland.com
Whtehnda93DXSdn is offline   Reply With Quote
Old 06-07-2002, 10:55 AM   #6
onesojourner
so is the H1 the high beam or is it the H3? if i do lighting on my car im getting HID thats why im asking. and what bulb are they using when just the ring is lit
don't like my post
videos
Old 06-07-2002, 12:10 PM   #7
iLLuCiv99
iLLuCiv99's Avatar
Send a message via AIM to iLLuCiv99
Yea for projectors its h3 low beams and h1 high beams
J+L
iLLuCiv99 is offline   Reply With Quote
Old 06-07-2002, 01:28 PM   #8
onesojourner
hmmm well you can get a HID kit for the h3 but i think its going to be butt expensive. unless any of you guys know where to get emm at.
don't like my post
videos
Old 06-07-2002, 01:59 PM   #9
Rice-Rocketeer
That's why you need to hook up the wiring harness, Are you sure you connected it right? Also check the fuses and the connectors on the relays to see if they look burnt or damaged in any way.
As for where you can HID lights from, I'd check GBC, they always good deals on them. Then there's a sight called HIDlighting.com or something like that. You can search it on www.google.com
Old 06-07-2002, 03:26 PM   #10
onesojourner
ok i found the h3 on gbc. do the stock 92-95 headlights only have one bulb? i will need to buy an H1 bulb too right or do i have that on already? and those are the only 2 bulbs used in the angel eyes right. witch bulb lights up just the ring when you turn on the parking lights.
don't like my post
videos
Old 06-07-2002, 03:30 PM   #11
1995HondaCivic
1995HondaCivic's Avatar
Send a message via AIM to 1995HondaCivic
dang how much did you pay for those bad boys?
1995HondaCivic is offline   Reply With Quote
Old 06-07-2002, 03:46 PM   #12
onesojourner
they are 200 on gbc i dont know if thats shipped though
don't like my post
videos
Old 06-07-2002, 04:00 PM   #13
soul180
soul180's Avatar
each of the ring connectors of the wiring harness is supposed to go onto the positive battery terminal, i thought thy would go one on negative, one on positive, but mine only work wheh both are on positive, try that, hopefully it'll work, mine work perfectly and i love thems ooo much, but i want the angel eyes like ytou have...i'll have to settle for paintin the housin on my current ones.
UGSTYLES
soul180 is offline   Reply With Quote
Old 06-07-2002, 05:00 PM   #14
onesojourner
come on guys what makes the ring light up?
don't like my post
videos
Old 06-07-2002, 07:12 PM   #15
Rice-Rocketeer
Dude, I explained all of this already. The stock headlights are a one H4 bulb system per housing. The H4 does both the low and high beam. If your gonna HID the stock headlighta you need an H4 HID kit.
Projectors use a dual bulb system. The H3 bulbs take care of the low beams and the H1's, the high beams. If you wanna HID the angel eyes, you need to use an H3 bulb system. The high beams don't matter anymore because the HID system will be bright enough where high beams don't offer any more visibility.
As for what bulb just lights up the ring with the parking lights, I haven't bothered to find out. The H3 lights probably take care of that as well. But it doesn't matter because the HID kit doesn't affect the ring.
The ring connectors are power sources for the headlights, you always connect power to the positive terminal. The negative terminal is ground. The harness already brings two ground terminals that you need to hook up to a suitable grounding point near the headlights.
