Go Back   Automotive Forums Car Chat > Saturn > Vue
Old 12-12-2010, 11:10 AM
nette_282 nette_282 is offline
06 Front wheel bearing hub removal.
I have made 2 attempts at replacing both sides, and in both attempts, could not get the hub to break free from the plate. What tool or method is used to remove hub? My service manual just says "Remove It" no note for any type of puller. Auto zone guys all saying it should just pop out, but I have beat and banged and pulled evan put the tire back on and beat on it with nothing breaking free. Yes, removed all 3 bolts, spindle nut, and on the second attempt, evan put a jack under the suspension and had the shaft loose.
Old 12-12-2010, 12:40 PM
Scrapper Scrapper is offline
AF Premium User
Re: 06 Front wheel bearing hub removal.
did you get halfshaft or axle loose from the hub and tie rod,strut,lower balljoint? you may want to take stable/lizer links and bushings loose?
Old 12-15-2010, 10:23 AM
RickCJ7 RickCJ7 is offline
you have an axle nut, 3 bolts thru the inside, and your abs sensor.
Usually a couple wacks with a mallet will loosen it
Old 12-15-2010, 12:46 PM
I tried everything I could think of, and could not get it loose. I evan put the wheel back on the hub and beat the crap out of it with a mallet. After giving up, I was at Autozone and I finally got an answer that may have worked, but bad weather set in and I had enough. The answer that made the most sence was a tool that looks sorta flat with 3 holes favoring one side, and 1 adjacent. This tool would bolt on to the hub with 3 lug nuts, and with probably a 1/2' threaded center that you can screw the slide hammer into, and then just hammer it out. That MIGHT have worked, but as usual, I get the best information after the fact every stinking time.
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
2002 Chevrolet Cavalier I trying to replace the drivers side front wheel bearing hub sixwongs Cavalier Problem Diagnosis 2 09-08-2009 11:20 AM
front wheel bearing/hub assembly.1999, S-10 p-up tcltom Engineering/ Technical 6 08-02-2009 10:25 AM
Axles and front wheel bearings/hubs chief153 LeSabre 5 07-20-2009 04:50 PM
