Go Back   Automotive Forums .com Car Chat > GMC > Yukon
Old 11-18-2010, 08:41 PM   #1
rdwright
2000 Denali Oxygen Sensor
I have multiple error codes relating to O2 Bank 2 Sensor 1. Can anyone tell me where this sensor is located?
rdwright is offline   Reply With Quote
Old 11-18-2010, 09:33 PM   #2
old_master
Advisor/Moderator
old_master's Avatar
Re: 2000 Denali Oxygen Sensor
DTC's tell you what circuit a fault was detected in. They do not tell you to replace a part. DTC's must be diagnosed and repaired, (one at a time) in the order they are retrieved. Then clear the memory and perform a drive cycle to confirm the repair. http://www.obdii.com/drivecycle.html If a DTC is set during or after the drive cycle is complete, repeat the process. Bank 2 sensor 1 is the upstream sensor, (closest to the exhaust manifold) on the passenger side.
You have to know how it works,
to figure out why it doesn't.
old_master is offline   Reply With Quote
Oxygen Sensor sasheehan Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 6 04-01-2012 09:19 PM
2000 Yukon Denali - Oxygen Sensor roman35 Yukon 15 12-27-2011 08:41 PM
02 sensors CEL but thats not problem Forduser1234 Windstar 1 05-28-2010 09:22 AM
o2 sensor danielgast46 F Series 0 03-15-2009 10:39 PM
2000 Denali shock sensor (for alarm) goinbig Yukon 5 04-13-2005 07:13 PM
