Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 10-17-2010, 09:22 PM
Bunky1267 Bunky1267 is offline
Question Blower motor and Sway bar Bushings
I have a 94 Olds Silhoutte (sorry got no resonses in the old forum) I need to replace the sway bar bushings on the lower control arms, the replacements I got are just the rubber bushings, and when I took the originals off the bushings were molded into the straps, Do I need to buy new straps or different Bushings with the straps..
Also my blower motor went bad, (press on type fan) and the replacement I bought doesn't have the hole in the side of the motor, do I need to get a different blower motor or was this hole eliminated ?
Old 10-18-2010, 06:59 PM
LMP's Avatar
LMP LMP is offline
Re: Blower motor and Sway bar Bushings
..WEll...Silhouette, APV, Transport.....all the same. Hole:...you mean that hole that carries some air to cool the motor ?......WEll, it was not enough anyway to keep the motor from frying on HIGH. Bottom line: HIGH is for short bursts only.....it draws 25 amps....lots of heat. Continuous operation only on 2nd highest setting.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 10-19-2010, 08:48 AM
LMP's Avatar
LMP LMP is offline
About the rubber bushings..ROck AUto's catalog shows them already molded to shape....but if they fit in place, I'd use the existing metal straps....the rubber will take the shape....
1996 Explorer with blower motor issues CREESERFARM Explorer | Explorer Sport Trac 13 02-03-2011 02:13 PM
Rear Sway Bar bushings and bracket henrymv Accord/TSX/Accord Hybrid 0 10-18-2004 07:50 PM
Stock Sway Bar Bushings Huey Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 3 03-17-2003 10:10 AM
Replaced my rotten front sway bar bushings and lugs... FourthGenHatch '88 - '91 Civic | CRX | Wagon | Shuttlee 2 09-12-2002 07:05 PM
