Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 09-03-2010, 08:52 PM   #1
tomshaze
i cant find the problem!!!!
hello i have a 2006 grand prix gt bought about 9 months ago tuned it three times full boltones e85 ran a 13.3 2 weeks later i take it bake to the track and it ran like shit
i got maf code or map
replaced both and the car did the same time
it misfires in high rpm
i get a blinking cel
my history of codes since the problem
p0171
p0107
u0107 ???
p0306
p0116
i am guilty of pouring water on the motor to cool it down before a race a couple of times people say that could of shorted it out
but hurrs my expierence
my fuel pressure drops from 60 to 58 ok i know that bad but i dont think that is enough to mess me up so bad
i am starting to belive its the wiring harness or the ecu
HURR THE WIERD PART!!!
ok so i conect a scan tool up to the computer at idle
it says 1.61 to 2.08 somthing/m
and the caclated load is 49 % with ac at idle
i have swapped 3! yes 3 maf sensors and the all have the same reading
i step the gas in park and the calc idle drops to 34% to 29%
ok so i test the 5 volt referecne wire that connects to the ecu
it 5.003 volts with the car off with the key forward i plug the maf and it drops to 2.5 i go to 3000 rpms in park and the voltagle fulcuates be tween 2.4 and 2.6 should it go up????
yes all three mafs have the same reading
the car can feel great ill get up and go fast!
the i turn it off and it will runn like a old tired dogg
please help me i am so stumped!!!!
tomshaze is offline   Reply With Quote
Old 09-03-2010, 09:07 PM   #2
tblake
In God We Trust
tblake's Avatar
Re: i cant find the problem!!!!
What is the voltage going to the MAF sensor read with the MAF unplugged key on? I thought MAF's get all 12v B+. Also does it have a good ground?
Why are you pouring water on your motor to cool it down? That can cause all sorts of issues up to and including cracked exhaust manifolds/ cracked heads or a block. Thats not a good idea.
Why not just install the ZZP electric water pump and wire it and your fans to on on/off toggle switch. That will cool down your car pretty quick. Along with that you could probably install a higher capacity radiator.
-2000 Grand Prix GTP 170,000mi (daily driver)
-2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal)
-1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix])
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
"I'll Keep my Guns, Freedom, and Money. You can Keep the Change!"
----->>>>> Did You Know? <<<<<-----
tblake is offline   Reply With Quote
Old 09-03-2010, 09:11 PM   #3
tomshaze
i was gunna buy that already but the this problems started!
yes it has good ground 12.43 volts the referecece wire is suppose to be 5 volts with the key on and it is but its suppose to increase and it doesnt increase a lot
Old 09-03-2010, 09:19 PM   #4
tblake
In God We Trust
tblake's Avatar
P0306 is a cylinder 6 missfire. I'd start there as you could be tossing a lot of money into a motor with a chipped piston.
Have you done a compression test?
I dont know much about running and tuning for e85, but you have to run larger injectors, right? And if so, your PCM is tuned for larger injectors, right?
How many miles, and is thes a 3800NA or 3800SC motor?
Old 09-03-2010, 09:23 PM   #5
tomshaze
the plugs look great it only misses at high speeds and sometimes the car felt great like it used too
and sometimes it feels horrible
i only got that code once
its a 3.800 sc
Old 09-03-2010, 09:25 PM   #6
tomshaze
yes its tuned on 60# injecotor was making 290 whp 290 whtq no intercooler stock trans stock heads stock cam in 100 deg weather with a header leak
Old 09-03-2010, 10:19 PM   #7
tblake
In God We Trust
tblake's Avatar
What all Mods do you have besides larger injectors, headers, and a customer tune?
What was your KR readings (WOT, Burst, cruising) at when you did your tune?
I still think a compression test would be a good idea first. Since a hairline crack in a piston can cause a problem much like you describe.
Old 09-03-2010, 11:58 PM   #8
tomshaze
no man im sorry but im sure its a electrical problem
Old 09-04-2010, 01:45 AM   #9
tblake
In God We Trust
tblake's Avatar
Maybe.
But the P0306 scares me. Plus the lean code.
Old 09-04-2010, 09:35 AM   #10
BNaylor
BNaylor's Avatar
Did you pour any water over the area of the coil packs and ignition control module?
Also, I'm confused on the fuel. Are you running E85 or premium unleaded at least 91 octane or better?
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline   Reply With Quote
Old 09-04-2010, 12:24 PM   #11
tomshaze
im running e84 i was getting 15.5 mpg before this problem one e85 no im getting 14.6 and dropping
no i did not those codes and nothing its only caused by my electrical issue cuz the sensor isnt reading right my maf voltage doesnt increase it just flucates my idle cacledated load is 50 percent and drops to 30 percent at 3000 rpm
thats what scares me also my temp guage stoped working yesterday i went out there and disconnected the wires from my ecu and recconected them and wham it worked fine again
Old 09-05-2010, 01:15 PM   #12
BNaylor
BNaylor's Avatar
Tim did you understand what he was saying? ..................
Mozilla/5.0 (Linux; U; Android 2.1-update1; en-us; DROIDX Build/VZW) AppleWebKit/530.17 (KHTML, like Gecko) Version/4.0 Mobile Safari/530.17 480X854 motorola DROIDX
Old 09-05-2010, 01:35 PM   #13
tomshaze
Old 09-06-2010, 02:11 AM   #14
tblake
In God We Trust
tblake's Avatar
Hmmmmm, tough one.
I dont no if he got it 2 werk by re-seating the pcm plug, or if he still has issues.
I'm not even good at it when I'm doing it intentional.
Old 09-06-2010, 02:15 AM   #15
tomshaze
well anyways i bought a zzp 350 pump cuz i tested my fuel pressure 60 psi at idle drop to 56 full load or 54 so im replacing it hopefully that helps with my leaness
Tags
ecu , harness , maf , sensor , wiring
