Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 09-10-2005, 11:37 AM   #1
abs10
1995 Blazer rear end interchange info needed
The 1995 Blazer s10 I recently purchased (4.3 V6, 4WD, auto) has a sheared pinion gear.
I'm guessing it would be cheaper for me to just swap out a used rear end than have a
specialty shop set me up with a new gear and posi assembly. What rear ends will
interchange with my '95 with a minimum of aggravation?
Thanks in advance.
AB
abs10 is offline   Reply With Quote
Old 09-10-2005, 12:09 PM   #2
OverBoardProject
Banned
Re: 1995 Blazer rear end interchange info needed
The wreckers have the chart, I would think pretty much every one out of a second gen with your same gear ratio.
Try getting one with a posi
OverBoardProject is offline   Reply With Quote
Old 09-10-2010, 12:03 PM   #3
deepbass9
If 95 is anything like my 94, look in glovebox for the code chart. See if there is a code of either GU4 or GU6. This would be the code for which rearend you have.
deepbass9 is offline   Reply With Quote
