Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-22-2010, 01:49 PM   #1
shuashef
Stiff steering but fluid tank full
My '96 camry is having very stiff steering but the sterring fluid tank is full. Any suggestions?
shuashef is offline   Reply With Quote
Old 08-22-2010, 02:01 PM   #2
mcmalloy
Re: Stiff steering but fluid tank full
does the pump make any noise when you try to turn, does the pump get hot with the enginge running?
mcmalloy is offline   Reply With Quote
Old 08-22-2010, 02:03 PM   #3
danielsatur
1) Block the rear wheels.
2) Jackup the front end.
3) Use a turkey baster to suck the extra fluid out.
4) Make sure you are using the right fluid, because some newer pumps use transmission fluid.
5) With the engine running, turn Left & Right to exercise the pump.
danielsatur is offline   Reply With Quote
Old 08-22-2010, 02:10 PM   #4
Brian R.
Resident Chemist
Brian R.'s Avatar
Send a message via Yahoo to Brian R.
Also, make sure the tension on your PS belt is adjusted correctly.
If you have not changed the fluid in the PS system in the last 50k miles or so, flush the system and put in all new ATF. There is a post in the FAQ thread on this.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
Old 08-22-2010, 07:15 PM   #5
shuashef
what is the PS system and how do you flush it out?
Old 08-22-2010, 10:27 PM   #6
Brian R.
Resident Chemist
Brian R.'s Avatar
PS = Power Steering
Flushing the system is well described here.
Old 08-22-2010, 10:32 PM   #7
danielsatur
Do Google ''Youtube auto power steering flush''
