Old 05-10-2003, 11:57 AM
Camber's Avatar
Camber Camber is offline
Send a message via AIM to Camber Send a message via Yahoo to Camber
Alright, I need a definate answer if it will bleed
Ok, Im going to paint a car white with a black roof. If I use tamiya tape, and press it down extremely firmly, then spray Tamiya TS Laquer black on the roof, will it bleed through? I need a deffinate yes or no answer. If it bleed, ill cry.
Old 05-10-2003, 12:33 PM
flyonthewall's Avatar
Car Mod guy
From my experience Tamiya tape works perfectly. I've only had problems with bleeding when brush painting.
Old 05-10-2003, 12:34 PM
Sidewinder-03's Avatar
Sidewinder-03 Sidewinder-03 is offline
It shouldn't bleed if you burnish the edges real good(rub down with a finger nail or something similar) especially where one strip of tape overlaps another strip.
Here's a little tip that I use: Cut the edge off with a fresh blade and a metal straight edge. The fresh edge is alot cleaner than the edge it came with.
Also, don't spray heavy coats. Spray 2-3 thin coats followed by 1-2 wet coats.
Current projects:
Caballo Diablo ('05 inspired '66 Mustang)
Extreme Firebird (on hold)
Major setback!!!
Paint screwed, body stripped, now have to redo the bodywork.
Old 05-10-2003, 12:35 PM
Veyron's Avatar
Veyron Veyron is offline
Smile
It won't bleed but it might leak under if it isn't pressed all the way down. I would give it a light coat of clear to seal the tape, then about two coats of black, ten minutes between each coat.
Old 05-10-2003, 01:36 PM
Camber's Avatar
Alright, thanks a lot guys
Old 05-10-2003, 09:42 PM
primera man's Avatar
"P-Man"
If you use Tamiya tape and press down will on the edge you should be fine.
The very first coat you put on must be a very light coat. This helps to seal the masking line with paint first. Allow to dry then spray
View All My Models Here.
Old 05-10-2003, 09:44 PM
irupp33's Avatar
irupp33 irupp33 is offline
Send a message via AIM to irupp33
heres a lil tip. after you lay the mask down spay some clear to seal any where it MIGHT bleed through then lay down you color. light coats at first gradually increasing the amnount of paint each time.
1991 Eclipse GS-T
Exterior: stock
Interior: Boost and A/F gauge, TV/DVD player, thats about it.
Motor: supra side mount, hard pipes, greddy type s, greddy profec b b/c, nology hotwires, 3 in. turbo back exhaust.
Wheels and tires: stock shitty fan rims with stock tires (no grip what so ever)
Old 05-11-2003, 03:18 AM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
I have a question concerning masking... how long should you wait before taking the masking off? I think if you wait too long and you take it off too late it might make the edges jagged, but can you really take masking off a recently painted car without it falling or something? I just remembered my Lamborghini
Old 05-11-2003, 04:40 AM
BOOSTD's Avatar
BOOSTD BOOSTD is offline
When I painted my Tamiya NSX I masked off the roof from the body using Tamiya tape. It worked great and didn't bleed, just make sure you take your time and make sure all the tape is pressed down firmly. I pulled the tape off about 10 minutes after I painted and it left a nice smooth line. Hope this helps.
Old 05-11-2003, 08:39 AM
daggerlee's Avatar
Just be very, very careful
Dan
Old 05-11-2003, 08:41 AM
yellow15's Avatar
yellow15 yellow15 is offline
No it won't bleed . I just finished a S15 with black roof a few weeks ago (the body masked using the tamiya masking tape when painting the roof) and it was the first time i use the Tamiya masking tape and the result was simply awesome:
DRAW PHOTOGRAPHY
Old 05-11-2003, 02:30 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Two more tips:
Before removing the masking tape, cut the paint layer along the edge with a sharp knife. That will make the boundary line very sharp.
If it bled, wait until it's dry, and carefully sand it with a fine sand paper, such as 2000 grit.
Hiroaki Fukuda
