Go Back   Automotive Forums .com Car Chat > MG > MGB
Old 07-03-2010, 05:39 PM   #1
Sean London
MGB was startin go ...became intermittent and now won't sutrn over just relay click
75 bought a few monthe ago. Ran ok...then began not to turn over. Rotated ignition switch rapidly and it started...then one day only click of relay and fuel pump no starter engagement. Put in new started...zilch!:frown:
Sean London is offline   Reply With Quote
Old 07-09-2010, 11:11 AM   #2
paul J
paul J's Avatar
Re: MGB was startin go ...became intermittent and now won't sutrn over just relay cli
Sounds to me like you have a bad ground. Check the ground from the battery to the body and check the ground from the chassis to the engine! Either one or both will cause this problem. PJ
paul J is offline   Reply With Quote
