Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 08-09-2010, 01:35 PM
travis2822 travis2822 is offline
Send a message via Yahoo to travis2822
95 Ranger A/C question
I recharged my A/C this weekend and the air is cold on Max AC only. It I move to the other 2 settings, the air begins to blow warm then hot. If I move it back to Max it is super cold again. Any ideas why it won't work on the lower setting.
thanks,
Old 08-12-2010, 03:46 PM
Davescort97 Davescort97 is offline
Escort guy
Re: 95 Ranger A/C question
The vacuum line going to the blend door is leaking or off . Check for leaks around the intake manifold and the heater/air conditioner.
Old 08-16-2010, 09:07 AM
The blend door is behind the glovebox correct?
Thanks for your reply. I'll check it out.
Old 08-29-2010, 12:33 AM
rum runner rum runner is offline
uhmm..........the vacuum line you are looking for is under the hood. The line is the tiny hard vacuum line........they have a tendency to come loose and/or crack. Ford/Motorcraft does not make this line in bulk, you have to buy small sized rubber vacuum line and slide it over the factory line to make repairs.
