Old 06-17-2010, 10:29 AM   #1
MultiLuminaowner
1997 Lumina won't Start
My son has a 97 Lumina that won't start. When turned to the start position, the headlights go off but there is nothing. No sounds, no click, nothing! After trying to wiggle key, putting in neutral, turning the steering wheel, nothing! I let it set for 10 minutes and then it started. Drove it shut it off started it pulled in to garage and the next morning he went to go to work and nothing??? Anyone have a suggestion before I call mechanic?
MultiLuminaowner is offline   Reply With Quote
Old 06-17-2010, 02:15 PM   #2
maxwedge
A990 racer
Re: 1997 Lumina won't Start
Clean and tighten the battery cables.
Old 06-18-2010, 09:36 AM   #3
MultiLuminaowner
maxxwedge,
The battery is not the problem. The lights come on and everything works. When turned to start on the ignition, the lights go out as normal but then there is silence. After letting it sit and trying again, it will start. Like I stated earlier, my son tried to start the car to go to work at around 8:00 am and nothing, I went out at 12:00 and it started up, I drove it to help at a local triathlon and had no problems.
Could it be the pass lock system on the key itself that is causing the problem??
Old 06-18-2010, 10:55 PM   #4
dennisinmo
It could still be the battery connections like maxxwedge said. A lose, dirty connection will still let a small amount of current through the connections to turn on the lights, etc but not enough for the starter. Maybe a lose connection at the starter or starter relay. Don't know if the newer cars have the neutral switch in series with the starter. That used to make intermittent problems. Jiggle the gear shift while the key is in the start position and see if it starts.
Good luck.
dennisinmo is offline   Reply With Quote
Old 06-19-2010, 01:41 PM   #5
maxwedge
A990 racer
Security system, if an issue, the lite on the dash would not go off, take the stated advice to begin the diagnostic process.
Old 06-21-2010, 07:03 PM   #6
MultiLuminaowner
Thank You maxwedge for your input!
Old 06-21-2010, 07:04 PM   #7
MultiLuminaowner
Thank You dennisinmo for your input!!!
Old 06-25-2010, 03:12 PM   #8
bsr2002
My security light has come on to and I too am having this problem. Also to note when the security light was on I noticed a red light below it that says VOLTS.
I will check the battery cables.
2003 Trailblazer LS 4.2L
www.facebook.com/bennyrillo
bsr2002 is offline   Reply With Quote
