Old 05-06-2003, 09:40 PM
Zum_speed Zum_speed is offline
Question D16y8 question
I posted a thread a litle while ago about engine swap for my 88 civic Lx(sedan) so now after checkin out my possibilities , im thinkin of doin a d16y8 swap....I thought it would b a good swap since its pretty cheap and it would still give me a litle bit more power than my stock engine.....I was wonderin if this swap would b a direct bolt on with my tranny and evrythin else. I was also wonderin if there are a lots of aftermarket stuff for it and would it support turbo or NOS ??
Thanx!
ZUM_Speed
Old 05-06-2003, 11:07 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
there is pretty good aftermarket support for it, it would support nitrous and or a turbo but with proper building unless your gonna run low boost or a low shot, there is however more aftermarket support for the z6 also SOHC VTEC, if you plan on going crazy with this thing i would recomend a z6 if you just want some bolt ons and some nitrous you can stay y8, either is a good swap
2002 Acura TL Type S
1991 Honda Crx Si
Old 05-06-2003, 11:11 PM
91civicDXdude's Avatar
91civicDXdude 91civicDXdude is offline
Send a message via MSN to 91civicDXdude
go with the y8. there is the same aftermarket support because they are essentially the same engine with a couple of changes. Also, if you plan on NOT converting to OBD1 or OBD2, the y8 is a better choice because your stock distributor will bolt on with no problems.. with the z6 you have to do some hacking at it to make it fit.
What makes you think you should be spoonfed?
http://4thgencivic0.tripod.com
Old 05-06-2003, 11:13 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
from what I hear the z6 is easier to wire.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 05-06-2003, 11:16 PM
its exactly the same. I belive the y8 might have a knock sensor since its OBD2, but not sure.
they are essentially the same engine.
Old 05-06-2003, 11:18 PM
they dont make that many diff cams for the y8 as they do z6 or even a6 :buck
1991 Honda Crx Si
Old 05-06-2003, 11:20 PM
not sure if you knew it, but you can put any z6 cam in a y8, there is just an issue of cam timing. you'll have to re-degree the cam. its something like 3 degrees off which can be fixed with an adjustable cam gear.
Old 05-06-2003, 11:38 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
it's not the same wiring when it comes to MPFI conversion. honda has that lovely habbit of changing injector impedance (sp?)....so they changed it again with the y8. i have yet to find info that addresses this problem for the dx/lx DPFI on the net....since i have an si we didn't have to deal with it.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 05-07-2003, 01:25 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
but isnt there something about the number of splines wrong on the input shaft or something ?
Team Lonely Drivers
Old 05-07-2003, 12:13 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Everything should be the same...
Just get the P28 ECU and distributor from a D16z6 and a wiring harness from [email protected] Then all you have to do is extend 8 wires and you'll be set up for OBD1. That's what I'll be doing.
