Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 03-05-2010, 12:54 PM
katie_parker katie_parker is offline
96 JGC help
ok first off id like to say im new here and was reading around to see if i could find out what was wrong with my jeep but havent found out yet anyways. i have a 1996 jeep grand cherokee laredo 4.0 4x4 well sometime i have a hard time starting my jeep you can roll it over but it wont start and you have to hit the gas for it to start and then when it starts you have to keep your foot on the gas or it dies out meaning it wont idel on its own. so i put a tune up on it like new cap rotor plugs and wires and it still does it some time. the check engine light isnt on so i dont know whats wrong with it anyhelp would be nice
Old 03-17-2010, 08:41 PM
nova73noir's Avatar
nova73noir nova73noir is offline
Re: 96 JGC help
bad connection to the batterie or fuel pressure
98 grand cherokee limited 5.9 swap 249 for 242 tc
73 nova 350 powerglide
90 z-24 3.1
95 mustang 3.8
Old 03-17-2010, 11:24 PM
dornier34's Avatar
dornier34 dornier34 is offline
Send a message via Yahoo to dornier34
Thumbs up Re: 96 JGC help
Originally Posted by katie parker View Post
ok first off id like to say im new here and was reading around to see if i could find out what was wrong with my jeep but haven't found out yet anyways. i have a 1996 jeep grand cherokee laredo 4.0 4x4 well sometime i have a hard time starting my jeep you can roll it over but it wont start and you have to hit the gas for it to start and then when it starts you have to keep your foot on the gas or it dies out meaning it wont idle on its own. so i put a tune up on it like new cap rotor plugs and wires and it still does it some time. the check engine light isnt on so i dont know whats wrong with it any help would be nice
Hi there , ok looks like you have a fuel problem , try to replace the fuel filter, if you did replaced and continue in the same problem , check the crank position sensor, behind the engine, left side between the top of the transmission comun problem. letme know
Old 06-02-2010, 12:29 AM
bub48161 bub48161 is offline
Re: 96 JGC help
it sounds like its the air idle control valve on the throttle body. pop it off and clean it and see how that works for you.
Old 06-25-2010, 01:16 PM
mastertech1964 mastertech1964 is offline
Re: 96 JGC help
it would also be a good idea to clean the throttle body if its never been done they can become so gummed up that the iac motor simply doesnt have enough range to compensate for the coked up throttle body
