Go Back   Automotive Forums .com Car Chat > Lincoln > Town Car
Old 05-12-2010, 05:11 PM   #1
iloveoldcars
Question trans problem? URGENT!
I have a 1989 Lincoln Town car. While driving my car today I noticed that it was revving a lot before it shifted, and it didn't seem like it was shifting normally. I think it was shifting into second around 30 mph then it would drive normally until it got up to around 45 mph - then it would start revving again. I was thinking it could be a transmission problem. I tried checking my trans fluid (I think it is the dipstick with the black handle to the left of the engine - it has a reddish fluid inside) and it seemed full. What could be the problem.
iloveoldcars is offline   Reply With Quote
Old 05-12-2010, 05:18 PM   #2
All2kool
All2kool's Avatar
Re: trans problem? URGENT!
How many miles on the transmission? The fluid should have the consistency of motor oil. Old and tired fluid can result in the symptoms you describe as well as just age of the transmission. Fortunately, the transmission in your car was manufactured by the millions and easily replaced. It isn't even a hard job with some knowledge and proper tools. It's the Ford AOD; millions and millions made. If you're going to have the unit removed and serviced, you may as well replace it with a re-manufactured one with a warranty.
All2kool is offline   Reply With Quote
Old 05-12-2010, 06:03 PM   #3
iloveoldcars
Are you saying it might just need a flush - or I am most likely to have to replace it?
Old 05-12-2010, 06:14 PM   #4
All2kool
All2kool's Avatar
If it were mine and replacing was less than $100 than having it rebuilt I would replace. If the trans has less than 100k it is worth repair; more than 200k, replace it.
Old 05-12-2010, 07:51 PM   #5
iloveoldcars
It has about 180,000 miles on it. It's original (as far as I know). Do you know if the transmission has a modulator on it?
Old 05-14-2010, 08:19 AM   #6
junk yard doggie
junk yard doggie's Avatar
I just seen this post about the transmission. Yes definitely check that TV cable like I mentioned in the other post.
Mike aka JYD
junk yard doggie is offline   Reply With Quote
Old 05-15-2010, 05:13 PM   #7
iloveoldcars
I just flushed the trans and replaced the filter. It is shifting great now!
Old 06-15-2010, 11:09 AM   #8
All2kool
All2kool's Avatar
Way cool.
Old 06-16-2010, 09:22 AM   #9
Kitt1993
Kitt1993's Avatar
I would also advise Lucas Transmission Treatment. After the flush. I flush my trans every summer and put a bottle of Lucas in it every time.
Nick names for my Car....
Abe Lincoln, opcorn:
The President,
Lucky Number 5
Kitt1993 is offline   Reply With Quote
