Well I have no clue when the last time the 98 had a new fuel filter in it. I know for sure not in the last 25,000 miles. So I bought a baldwin filter but don't know how to put it in. I will try to find a how to article but any help from you guys would be greatly appreciated. Thanks.
"Staging in the Dodge lane is a Talon, or Eclipse, or Plymouth, or Mitsubishi... Ok, I don't know what the hell it is, but it'll be turbocharged and it's going to school this Mustang." - Announcer at a track DSM power.
Re: I need to install a new fuel filter...
GM filters usually have either a quick connect fitting or a threaded fitting. I have found a 16mm and a 20mm wrench work well for the threaded fittings. If it has a quick connect fitting with the white plastic tangs pinch the tangs and slide off the fitting. If it has a black plastic cap on the quick connect push the black plastic piece towards the line to release the quick connect.
Thanks, that will be useful once I find out where the thing is. Ha, do you have to take out the backseat to get to it?
should be under the car near the fuel tank.
Do I need to access it through the wheel well or through the backseat?
You'll need to safely jack up the car and look underneath
Thanks. I'll report back once I've done the job.
It''s in front of the right rear wheel-well at the sill...easy access.
1999 Buick Century Custom 3.1L , 148,000km. 2000 Toyota Echo, 1.5L 220,000km |
