ignition problem no spark
I have a 1999 express van, 5.7 engine I just installed new multi- port injector ( BDW ).
and replaced the timing chain cover. the van started up right away. I drove it for about 5 miles. I got a few blocks from home it started to run like crap. I pulled over stopped the engine. I tried to restart it barely idled. the engine temp got to230 degrees. I let it cool off . when I tried to start it again all it would do is crank over. I put an in line spark tester on it . I have no spark. what can be the of this now?????? I have in the recent past installed distributor w/cap,rotor , new crank sensor , coil, plugs and wires the only thing in the chain I haven't replaced is the ( Ignition control module) is there away to test this thing? |
#2 | ||
Re: ignition problem no spark
Why did the temperature go so high make sure this problem is fixed as this will fry a module in the distributor. |
Ok I've had the ICM Tested it's ok. I have ohms tested the coil (ok) also tested the cam sensor and the crank sensor. I have 11.75 volts going to the coil on the high side and 6.3 mv on the low side. yet I still have now spark.. the engine turns over. I can smell fuel. what else can it be???? I'm stumped here... could some thing going on with the reluctor ring ?
#4 | ||
Ohm the wire on top of the distributor it should read approximately 1/2 scale. A rotor can go bad use an ohm meter and check. |
