Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 04-20-2010, 09:05 PM   #1
GTP Version 2.0
97 GTP Transmission leak
I was doing an oil change the other day and noticed that under the car near the radiator that there was a red fluid built up around the front undercarriage. I think it is coming from the transmission cooler line but I'm not sure nor can I see where they connect. Does anyone have a writeup on how to replace the line/hose?
GTP Version 2.0 is offline   Reply With Quote
Old 04-20-2010, 09:56 PM   #2
tblake
In God We Trust
tblake's Avatar
Re: 97 GTP Transmission leak
Cooler lines are common leak points on these cars. Mine had a new one replaced before I bought it with 70k on it.
I don't know of any write-ups. You could be the first one! as far as I know it is just a simple switch. Unbolt the old, bolt on the new. Someone on here mentioned little clips on the lines where they connect to the trans. If so, there is a special tool, otherwise a small flathead screwdriver or a nice pick set will usually work just fine. Although I could have swore the 4t65e's I've worked on had regular nuts where the lines bolted to the trans. (maybe I am thinking of the 4t60e). Troy would know.
-2000 Grand Prix GTP 170,000mi (daily driver)
-2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal)
-1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix])
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
"I'll Keep my Guns, Freedom, and Money. You can Keep the Change!"
----->>>>> Did You Know? <<<<<-----
tblake is offline   Reply With Quote
