91 Firebird w/ 305 TBI
After a few days of diagnostics to figure why my car wont start, i have figured out that something with the fuel delivery system is bad. My fuel pump doesnt turn on and i dont think the pump went bad cause i drove my car the day it stopped running and after i went to try to start it a few hours later, i couldnt. what else could be an issue if not the fuel pump?? I already replaced the fuel pump relay, i checked the 2 injector fuses too just in case it was the injectors and not the pump, but i cant even hear the pump turn on. It cranks and cranks but does not fire. I know the spark is good cause i can run off of starter fluid. I looked at the throttle body whil it was cranking and ther is no fuel squirting out of the injectors. Pump or Vats? not sure what i causing this to happen.
