2001 silhouette cooling fans
My 2001 when driving the temp needle will be at 1/4 way if I am in traffic it will go 3/4. I ideled it at home the cooling fans never kick in.
When ideling I cannot get heat but once I start moving I get heat. Thanks for any help |
Re: 2001 silhouette cooling fans
...potentially not a good sign...Is radiator filled to the top? Does it need topping with coolant/water often?
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. |
The radiator does need topped up maybe just over a cup of coolant each time
The fans won't come on until it gets around half way on the temp gauge, perhaps even a bit higher, ymwv but LMP is right, this could be bad news. The issue is the engine could have a manifold coolant leak which will behave just as you describe initially--particularly the part about poor heater performance.
You could have the coolant tested for contaminates--that would give you a better idea of what's going, but the general case with the coolant problems is the manifold gasket is leaking.
is the manifold gasket hard to replace what will that lead to if not fixed
If you wait too long then after the manifold gasket has been replaced, the cam shaft will seize up and snap, basically ruining the engine. This happened to three of these vans I've worked on and I replaced the engine with rebults. The rebuilder told me he has never seen a 3.4l chevy that didn't have bad cam journals. As far as doing the manifold job, its not bad; takes a novice a weekend to perform. Read the older posts on this and the chevy venture forums for instructions and techniques. |
