Go Back   Automotive Forums .com Car Chat > Ford > Contour
Old 03-16-2010, 11:54 AM   #1
barfarlanaa
97 2.0 wont start
i have a 97 contour 2.0 wont start have spark and fuel ( don't know pressure ) and timed perfectly but still wont start any advice at what to check
barfarlanaa is offline   Reply With Quote
Old 03-27-2010, 02:35 AM   #2
Davescort97
Escort guy
Re: 97 2.0 wont start
Clean the connector to the CKP (Crankshaft positon sensor) if that doesn't help replace the CKP.
Davescort97 is offline   Reply With Quote
Old 03-28-2010, 03:10 PM   #3
z28clone
I'd say get rid of the POS.
Found On Road Dead
z28clone is offline   Reply With Quote
Old 03-28-2010, 03:30 PM   #4
Ralph123
Ralph123's Avatar
Try spraying some carb cleaner into your throttle body while turning the key and see it fires up for a few seconds.
Ralph123 is offline   Reply With Quote
Old 03-29-2010, 12:21 AM   #5
Davescort97
Escort guy
He already knows the engine is getting spark and fuel. I don't see what difference carburetor cleaner is going to make. HOwever, starting fluid may make a difference.
Old 03-29-2010, 01:06 AM   #6
Ralph123
Ralph123's Avatar
He said he didn't know the fuel pressure. So how does he know his problem isn't fuel related? Carb cleaner acts the same as starting fluid when sprayed into the throttle body. If the car fires up when spraying carb cleaner into the throttle body it would indicate he has a fuel problem. If nothing happens when he sprays carb cleaner into the throttle body it would indicate an ignition problem.
