1998 Jimmy 4-Wh problem
98 Jimmy 180k, Shift to 4-WH and can hear actuator shift. 4W-L works also. Yet the front hubs do not lock. Button lights show no problem. Checked all fuses. None blown that I could find. Can not hear any vacuum leak. ???
Re: 1998 Jimmy 4-Wh problem
You may be hearing the actuator working in the transfer case but the actuator for the front differential may not be engaging. (If it has one).
If so, check to see if you have power going to it. Some actuator switches incorporate a gas cylinder that expands under heat from a power source.
A quick check at the auto part store indicates the your actuator is vacuum operated. Check for vacuum at the unit and test it with a vacuum pump tester.
Sorry about the previous post.
If the 4X4 lights don't blink, indicating a problem, then the actuator is working and activating the switch in the front differential. The left front axle is always engaged with the differential, if the right front axle shaft does not engage, (4WD will not work until it does), the problem is with the clutch shaft or linkage in the front axle that engages the right axle to the differential.
What I found on my Jimmy after a very long diagostic process was that I had some water dripping on the wiring harness into the Transfer Case Control Module. It must of shorted it because a couple of pins were very corroded. Harness plug had to be rewired. It still didn't work. Finally I broke down with the replacement of the TCCM which is $500. |
So, to be clear, with the front wheels off the ground, if I turn one wheel and the other wheel also turns (opposite direction, of course), the front differential IS engaged? I ask because I'm having intermittent problems with my front end DISengaging...(I think the cable might need to be replaced)
Thanx!
Chuck 2000 GMC Jimmy SLE 2006 GMC Trailblazer |
The Transfer Case Control Module (TCCM) located against the wall under the glove compartment. I would start there because it is easier than any further diagnosis which gets very involved if your doing it yourself. What you are looking for is corrosion on the wires going into the wiring harness. If you have that then it will involve (going to GM dealer - not off the shelf stuff) getting a new wiring connector ($20), the F-connectors ($32), soldering skills, and some patience. After that, it will cost $500 for a new TCCM (or go to a junk yard and get one at a steal). It all worked for me 100% (knock on wood). This might explain the intermittent 4-Wheel disengagement. No guarantee. Sounds similar to my situation. Good luck.
You have to know how it works, to figure out why it doesn't. |
Clutch mechanism on the passenger side front axle shaft is a new one on me...
Items 9 thru 23 show the cable, clutch and shift mechanism:
You have to know how it works, to figure out why it doesn't. Last edited by old_master; 02-15-2010 at 04:29 PM. |
