Go Back   Automotive Forums .com Car Chat > GMC > Jimmy
Old 01-12-2010, 11:54 AM   #1
jeffharley
Send a message via AIM to jeffharley
95 Jimmy remote oil lines
I'm wondering if anyone has replaced the oil lines from the motor to the filter? I can't see where the lines are connected to the engine or how to get to them. Any help would be greatly appreciated..Jeff
jeffharley is offline   Reply With Quote
Old 01-12-2010, 05:50 PM   #2
old_master
Advisor/Moderator
old_master's Avatar
Re: 95 Jimmy remote oil lines
Follow the lines back along the driver side edge of the oil pan. They change to aluminum near the front of the engine. There is one 13mm bolt attaching them to the oil filter adapter. Easiest if you get underneath.
You have to know how it works,
to figure out why it doesn't.
old_master is offline   Reply With Quote
Old 01-14-2010, 10:53 AM   #3
jeffharley
I can see the ones on the oil filter adapter, I can;t see where the ones are that are atatched to the motor. Can you get to them through the wheel well?
Old 01-14-2010, 02:39 PM   #4
old_master
Advisor/Moderator
old_master's Avatar
The oil filter adapter mounts to the engine, the remote lines attach to the adapter. The oil filter attaches to the remote mount which is under the center of the radiator. The cooler lines run to and from the remote mount to the radiator tank on the driver side. You'll need to get under the vehicle to to service the oil filter adapter and or line connection. It's very close to where the transmission bolts to the engine block, on the driver side. Not pretty to get to, but it can be done.
Old 01-15-2010, 08:39 AM   #5
jeffharley
Thanks..I will be having fun(NOT) this weekend replacing the lines
Old 01-15-2010, 03:48 PM   #6
old_master
Advisor/Moderator
old_master's Avatar
There are threads in the "How-to" section that tell how to do it. There are some that tell how to modify them so they won't leak again. If you choose to replace them, rather than modify them, do yourself a favor and use the ones made by Dorman, they last a little longer than the OEM lines.
Old 02-21-2010, 02:41 PM   #7
Rickochet
Rickochet's Avatar
While you are there, you might as well replace the oil filter adapter O-ring and gasket. I have been there many a time. The adapter bolts to the block where the oil filter is typically mounted with only 2 bolts and is a simple job, as long as you have your lines already off. It costs a few dollars for the O-ring & gasket from FelPro and it will save you many frustrations of having to do part of the slimy, greasy, messy task all over again.
Rickochet is offline   Reply With Quote
