Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Silverado
Old 12-21-2009, 03:22 PM   #1
mwelch75
Exclamation 2000 z71 trans problems
i have a 2000 1500 z71 with 212000 miles on it. the service 4wd light is on and the lights are not working for the 4wd shift selector. i think that the selector is bad. so on to the next problem. the truck is acting like it is stuck in low gear but the 4wd is not engaged and will not shift out of 1st gear. crazy thing is when you go to put it into park on flat ground the truck will roll until it hits the stop for the park gear. its almost like even though you shift out of gear there is still transmission pressure still be applied to the clutchs or somthin i do have some mechnical background but have never ran into a problem like this before any help would be great thanks
mwelch75 is offline   Reply With Quote
Old 12-21-2009, 03:57 PM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: 2000 z71 trans problems
Have you checked all fuses on both sides for 12 volts?
Did it all happen all at one time?
A transmission transpher case capable scanner may show codes or problems?
If any codes post back code no.
MT
Old 12-21-2009, 04:32 PM   #3
j cAT
on this problem. after checking fuses with a meter ...behind this 4wd selector switch is the 4wd controller ...this is where the 8 volts is created that operate all this...with the drive train codes posted we can help you..
Old 12-21-2009, 08:17 PM   #4
mwelch75
i will get a scanner and check the codes to find out what they are thanks
Tags
4wd , shifting , transmission
