Old 12-29-2009, 10:26 PM   #1
randall 37382
94 lumina fuel pump problem
trying too help a friend on there lumina. the car cranks but doesn't start. i pushed the bleeder on the fuel rail and got nothing. i do not here the fuel pump running. someone in the past cut the floor so i can actually get too the fuel pump with the tank in. i checked power too the pump and i got 12 volts to the gray wire and 8 volts too the purple wire. i don't have a wiring diagram too know what is normal. any help is appreciated.
randall 37382 is offline   Reply With Quote
Old 12-29-2009, 10:47 PM   #2
Bearwulf
Bearwulf's Avatar
Re: 94 lumina fuel pump problem
If the fuel pump is not running, yet you have voltage, have you checked for ground? If you have good ground, then it is time to replace the pump. The best one to use in the GM is the AC Delco.
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Bearwulf is offline   Reply With Quote
Old 12-29-2009, 11:04 PM   #3
randall 37382
good point, i didn't do a continuity test too ground. i think it is the pump but i just wasn't sure the wire i had power too was for the pump or if the gauge might have power also. now that i think about it the gray wire i had 12 volts too worked as it should and had power for a few seconds when the ign. was turned on. thanks.
Old 12-29-2009, 11:24 PM   #4
Bearwulf
Bearwulf's Avatar
Primer circuit yup! Most likely the pump is froze up or burned up inside.
97-Lumina LS
Old 12-30-2009, 09:33 PM   #5
randall 37382
does anyone have a wiring diagram for the fuel pump for the 94 lumina. id like too meter the wires out before i have them order a new pump.
Old 12-31-2009, 01:02 AM   #6
rcweston
My manual doesn't include a diagram for the 94 but it has one for the 98. Hopefully it will help.
Their is a six lead connector that supplies all connections to the gas tank on the side of the cavity of the car under body that holds the gas tank. The gray lead is power in from the fuel pump relay. It supply's the 12v. to the fuel pump.
Their are 2 black leads in this connector. One lead goes to ground and supplies ground for the fuel pump, a second black lead becomes both a second and third lead. They connect together on top of the gas tank. They are return leads for the fuel pressure sensor and the fuel level sensor.
The forth lead is purple. this lead is source lead (the other connection) to the fuel level sensor.
The fifth and sixth leads are dark green and tan. The tan is a 5v. supply to the fuel pressure sensor and the dark green is the pressure sensor input to the pcm.
Hope this is helpful.
rcweston is offline   Reply With Quote
Old 12-31-2009, 06:27 AM   #7
randall 37382
thanks RC, the top of the tank at the pump only has four wires. they sound like they may be the same, just missing the dark green and tan.
