Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 07-29-2009, 10:50 PM   #1
fastlane85023
Angry Rear end noise
I recently changed the right side axle on a 91 GT 5.0 and also the u-joints and now I am getting a horrible gear binding noise from rear end. I have tore it down 3 times and redone my work and dont know what to check next. Can someone help? Is it possible I need to set end play on pnion shaft? It is a 8.8 inch posi rear end,
fastlane85023 is offline   Reply With Quote
Old 07-30-2009, 12:33 AM   #2
MagicRat
Nothing scares me anymore
MagicRat's Avatar
Re: Rear end noise
Normally you do not have to touch the gear set up at all.
What happened to the old shaft? Was it damaged? Is it possible the inner or outer bearings are also damaged?
MagicRat is offline   Reply With Quote
Old 07-30-2009, 11:55 PM   #3
MagicRat
MagicRat's Avatar
Re: Rear end noise
You have sent me this note:
I also replaced the bearings. The kid the car belongs to hit a curb and bent the axle wheel plate let me know if you have any ideas.
Unfortunately, I think you may have additional damage. If the axle impact was inwards towards the differential, the axle tube, or lateral, the axle tube may be bent. If the impact was outwards, the differential carrier may be damaged.
Either way, it may be easiest simply to swap the entire rear axle, or at least take it to a shop for a professional diagnosis.
Old 11-26-2009, 10:28 AM   #4
gary turner
Re: Rear end noise
i also had the right axle replaced due to rear end noiise.didnt help so i just live with it
gary turner is offline   Reply With Quote
Old 11-29-2009, 08:39 PM   #5
fordtrucksonly
fordtrucksonly's Avatar
Re: Rear end noise
Sounds like carrier bearings...
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
fordtrucksonly is offline   Reply With Quote
Tags
8.8 , binding , end , posi , rear
