Old 11-21-2009, 07:02 PM
92_Lumina_Z34's Avatar
92_Lumina_Z34 92_Lumina_Z34 is offline
3.4l d.o.h.c
Engine backfires while turning over, but will not start.
Ran perfect a couple days ago.
Any input would be great.
Thanks in advance
Old 11-21-2009, 07:20 PM
danielsatur danielsatur is offline
Re: 3.4l d.o.h.c
What Elements do you need for a fire?
Air, Fuel, Ignition, and Timing.
This is a 1992 with a OBD I system, so there's less codes.
The backfire tells us, that you do have some fuel, and fire.
Doe's this car have a MAF sensor?
Old 11-21-2009, 07:34 PM
Re: 3.4l d.o.h.c
This car does not have a MAF sensor
Old 11-21-2009, 09:54 PM
Re: 3.4l d.o.h.c
1995 and newer have OBD II systems, these codes can help us troubleshoot.
Old School Troubleshooting -
1) How many miles are on this car?
2) How many miles are on the old plugs & wires?
Old 11-21-2009, 10:47 PM
Re: 3.4l d.o.h.c
1) Car has 142000 miles
2) Plugs and wires were changed about a month ago
Recently have done:
-timing belt (replace idler pulleys, tensioner, and hydraulic tensioner)
-replaced o-ring for distributor drive unit
-head gasket on rear bank
Old 11-23-2009, 02:01 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
Re: 3.4l d.o.h.c
Did problem start before or after changing timing belt? This car has the predecessor to the MAF which is the Intake Air temp. sensor.
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Old 11-23-2009, 01:55 PM
Re: 3.4l d.o.h.c
Problem started 2 weeks after the belt was changed. Car ran perfect. shut it down, went to start it the next day and it wouldn't start
Old 11-23-2009, 06:40 PM
Re: 3.4l d.o.h.c
It's all about timing!
1) Verify and check your timing.
A loose tensioner, could of caused the timing to jump a tooth.
http://www.automotiveforums.com/vbul...d.php?t=954555
