Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Members Projects
Members Projects Discussion of the AF 2G DSM Project Car
Old 02-28-2010, 04:07 PM   #1
boostjunkie333
boostjunkie333's Avatar
Send a message via AIM to boostjunkie333
Junkies 97 RS Rebuild(1st timer!)
Ok, For anyone viewing, it's a 97 RS obviously, and I will be attempting to remove the engine, rebuild, and re-install. Have plenty of money now thanks to financial aid, so now i'm gonna try to make my first build thread. Wish me luck.
Btw, i'll have pictures up tonight(when my gf brings my freakin camera back home) and i'll bring everyone up to speed where i'm at in the process.
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
boostjunkie333 is offline   Reply With Quote
Old 02-28-2010, 10:05 PM   #2
boostjunkie333
Re: Junkies 97 RS Rebuild(1st timer!)
Ok, figured out how to get the transmission off thanks to silver, I see what you meant about removing that lower cross member mount so that you can get to those 2 bolts...
I just dont have a 17mm wrench(this is the correct tool for the job right?)...need to run to the store tom. to get that.
I've got some pictures, let me figure out how to upload them properly sized.
Old 02-28-2010, 11:56 PM   #3
boostjunkie333
Old 02-28-2010, 11:58 PM   #4
boostjunkie333
Old 02-28-2010, 11:59 PM   #5
boostjunkie333
Sorry, just playing with imageshack to try and find the right size.
Old 03-01-2010, 12:12 AM   #6
boostjunkie333
So far i've removed the following
battery
ic piping
ic
radiator and hoses
down pipe
Next I think I might try to remove the turbo and manifold together, although the bolts for the manifold are giving me a problem getting to...and I can only get an open end wrench on them and mine keep slipping off
After that, I was gonna try to get the trans off, Which i'm guessing I only need to remove the cross member under it, and then the 4 bolts on the bell housing(correct me if i'm wrong please).
My wrench set only goes up to 16mm and the bolts are bigger than that so...gotta buy a few more wrenches....and thats where i'm at right now.
Old 03-01-2010, 09:39 AM   #7
david-b
Dave is THAT guy
david-b's Avatar
Looking good so far. What kind of rebuild are you doing? Stock?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
david-b is offline   Reply With Quote
Old 03-01-2010, 12:21 PM   #8
boostjunkie333
I already have JE pistons and eagle rods, just gonna keep them if they are not damaged...but umm...i'm not really changing anything for that matter...
The only thing im unsure about is the mounts. Should I purchase just inserts, or whole new mounts? or...?
Also, I noticed the inserts for the front trans mount are like...decrepid...how do I find new ones of those?
Old 03-01-2010, 07:33 PM   #9
SilvrEclipse
Holset powered 420a
SilvrEclipse's Avatar
Send a message via AIM to SilvrEclipse
Take out the bolts from the trans to the block, dont take out the bellhousings to trans bolts. If you spun a bearing then your probably going to need new rods.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
SilvrEclipse is offline   Reply With Quote
Old 03-02-2010, 12:47 AM   #10
boostjunkie333
Ok, got the turbo off, and the manifold, and starter. Got a few of the bolts on the trans loose just so I know I can get to them...so no problem there. I took some pictures but the camera died. So when its charged ill post. Tom. I will completely unbolt the trans and move it over, and I guess start unplugging shit.
Old 03-02-2010, 01:26 AM   #11
boostjunkie333
Old 03-02-2010, 01:27 AM   #12
boostjunkie333
First two photos are obviously the equipment I bought, and the next two photos are me getting that pesky turbocharger and manifold off...
Old 03-02-2010, 02:11 AM   #13
boostjunkie333
And silver, what do I look for to tell if the rods are bad?
Old 03-02-2010, 07:17 AM   #14
SilvrEclipse
Holset powered 420a
If you spun bearings then you should probably replace then. Im betting you did if you ran it low on oil and it was knockin
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 03-02-2010, 12:17 PM   #15
boostjunkie333
Ok. I was hoping to avoid spending another 350 bucks but, oh well. I would ask what a spun bearing looks like, but I suppose i'm about to find out.
