Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 10-04-2009, 12:51 PM
BADWENCH BADWENCH is offline
95 wiil not start
Have a 95 with 3.8 SC with 119K. Had a leaking intake gasket and would run ruff. I replaced the intake gasket as well as the SC gasket, also put in new plugs. Now engine will not start. Have 40 PSI at fuel rail, have spark when I crank. While cranking what type of vacuum should I have? Would you check at the vacuum tree on top of SC. I assume you must have vacuum for the fuel regulator to work? I have sprayed WD40 around the intake and head mating parts thinking maybe I still had a leak but that did not help.
Thanks for any help
Old 10-05-2009, 05:49 AM
maxwedge maxwedge is offline
A990 racer
Re: 95 wiil not start
Are the injectors pulsing?
Old 10-13-2009, 01:24 PM
No, but do have power to them, so it must be whatever tellsthem to pulse.
I even pulled the rail hooked the fuel line up and applied 12 v with ground and each would spray, so not what sure to check next.
Old 10-13-2009, 06:39 PM
A990 racer
Fuse bad, something unplugged?
