Old 11-14-2009, 08:01 AM   #1
Elk1007
Ridin Dirty
95 Lumina - Repetitive squeak
Sometimes when I drive, there is a repetitive squeaking, and then when I apply the break it goes away.
New pad time?
Also, my fuel gauge moves a lot. If I fill the tank to around 1/2, it will move from just above 1/2 down to 1/4, and in-between as I drive.
Is this something I can fix? What's going on?
And lastly, does anybody know the location of the EGR valve on a 95 Lumina?
I want to take a look before I go to smog it tomorrow.
Elk1007 is offline   Reply With Quote
Old 11-14-2009, 04:20 PM   #2
maxwedge
A990 racer
Re: 95 Lumina - Repetitive squeak
The squeak sounds like the brake pad wear indicators, the gage could be the sending unit in the tank and the egr location can be seen in a picture at autozone.com, repair guides, register and go to your car.
Old 11-14-2009, 05:54 PM   #3
Elk1007
Ridin Dirty
Thanks! Very helpful
The squeaking only happens when I DON'T apply the break, which makes me think it's not the wear indicators (as that would only make noise when applying the breaks) is that accurate?
Old 11-15-2009, 04:14 AM   #4
Bearwulf
Bearwulf's Avatar
Disc or drum rear?
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Bearwulf is offline   Reply With Quote
Old 11-15-2009, 09:39 AM   #5
maxwedge
A990 racer
That is the symptom of the indicators, the noise goes away when braking, 95 had drum rear. Pull the wheels and look, no?
