3.8L 95 windstar TRS Change... Any helpful hints?
We are getting ready to replace the TRS on my van. I have a couple questions...
1. My haynes manual says to mark the current position before removing old part. What exactly am I marking? 2. The manual also says to jack up the van & put it on jack stands. Is it really necessary to raise the van & if so will ramps work or does the weight need to be off the wheels? 3. The part comes in neutral, am I right when assume the van also needs to be in neutral? Thanks in advance, any helpful hints are very much appreciated. |
![]() Join Date: Sep 2004
Re: 3.8L 95 windstar TRS Change... Any helpful hints?
You will need to have the TRS position to match up with the Gear select.....so YES the correct position would be Neutral for the Gear select.
I note that this matches up with what they say in alldata as well. As you have the vehicle in Neutral.....put blocks in front of and in back of one of the tires....as well as setting the parking brake......to prevent vehicle movement. I am not sure why they say to raise up the vehicle......it looks like you do the job from above. You would remove the flex hose that goes from the throttle body to the air filter box. Some have stated that they pretty much destroy the old TRS in removing it.......it does not just lift off. Do NOT damage the shaft that passes into the TRS going down into the transaxle.
Moderator for Ford Windstar room only Links to my pictures, intended as an aid, not a replacement for, a good repair manual. 1996 3.8L Windstar http://www.flickr.com/photos/4157486...092975/detail/ 2003 Toyota Sienna pictures (not much there yet) http://www.flickr.com/photos/4157486...781661/detail/ |
#3 | ||
You don't need to raise the vehicle.
2003 Chevrolet Impala LS 3.8L OHV 2002 Ford Taurus SE 3.0L OHV (sold) 1998 Ford Windstar LX 3.8L OHV (sold) 2002 Chevrolet Malibu LS 3.1L OHV (sold) 2004 Hyundai Accent GS 1.6L DOHC manual (sold) 1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold) 2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold) A Windstar without having the check engine light is not a real Windstar.
