Register FAQ Social Groups
Old 12-10-2009, 07:42 PM
relic7680 relic7680 is offline
Question SBC: Edelbrock Torker I vs. Weiand 7546
I am contemplating a 388 stroker SBC build for my '76 GMC Sprint (El Camino). I already have the .040" over 350 4 bolt bare block. I want to build the motor to resemble the '78-'82 hot rod period (using modern iron heads and internals), and make 500HP on pump gas. Two old single plane intakes come to mind...the original Edelbrock Torker and the Weiand 7546. I understand that these will not perform quite like a modern design, but I want to be period correct and still make power for "street/strip" purposes. Which intake is better? Is my 500HP goal reasonable with either one?
close enough for government work........
'91 C2500 Silverado (8600GVW)
'89 Suburban R1500 Silverado
'76 GMC Sprint Classic
'76 El Camino Classic
Old 12-11-2009, 09:26 AM
MrPbody MrPbody is offline
AF -Advisor
Re: SBC: Edelbrock Torker I vs. Weiand 7546
Edelbrock wears engines out testing. T-1 was a good intake as long as low-end power is not a major concern. Weiand appears to "copy" what Edelbrock sells.
Neither are well-suited to your performance application. That A-body is quite heavy, calling for more low-end and mid-range than high-end power. The old C4-B is a decent "high rise" from the era, that will help with the low-end. Performer RPM is similar in appearance, but is FAR more advanced.
FWIW
Jim
Old 12-11-2009, 11:08 AM
Looked into the C4B and C3BX.....not sure if they will be aggressive enough for my application. Is there any pre-'83 intake that might do? Also looked at the old Holley Street Dominator...
Old 12-11-2009, 01:55 PM
AF -Advisor
The Holley is another "knock-off" of an Edelbrock. If these are the only choices, I would stick with Torker.
Jim
Old 12-12-2009, 05:08 PM
Found out that the C4B and C3BX won't clear my HEI.....going to look into the performance of the Torker some more. I appreciate your help.
