Go Back   Automotive Forums .com Car Chat > Buick > Roadmaster
Old 10-30-2009, 12:04 PM   #1
MadMyers
Instrument lights not automatically turning on when headlights automatically turn on
My 95 roadmaster has developed a problem. When the light sensor determines it is dark, the headlights automatically turn on. However, when this occurs the instrument panel lights do not turn on.
If I turn on the headlights manually (by pulling the lamp knob out one knotch) the instrument panel lights do turn on.
Perhaps related, perhaps not... When I manually turn on the headlights, the left turn signal indicator on the instrument panel remains lighted. It does flash, however, if I use the left turn signal.
Thanks in advance!
... Altan
MadMyers is offline   Reply With Quote
Old 11-19-2009, 06:55 PM   #2
MadMyers
Re: Instrument lights not automatically turning on when headlights automatically turn
No thoughts?
Thanks in advance!
... Altan
Old 01-02-2010, 12:45 AM   #3
gn1220
Thanks in advance!
... Altan
Sounds like the headlight switch is bad. You can get to the switch by pulling the fuse panel cover on the side of the dash.
gn1220 is offline   Reply With Quote
Old 04-18-2010, 07:38 PM   #4
Dougn2007
I have owned 4 roadmaster's, two of them had this problem. It is on a small circuit board down in the kick panel on right side. The circuit board will have a cold solder joint on one of relay leads, just fix it with a soldering iron.
Dougn2007 is offline   Reply With Quote
