Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro | Firebird > Camaro Discussions
Old 07-18-2009, 04:18 PM   #1
LV1
1979 Camaro and a B+m shifter?
Hi
I am trying to to get my friend's camaro back in working order after previous owner cobbled it together They put a b+m ratchet floor shifter in, It shifts hard, No b/U lights,start's in all gears. Anyone have a idea how to wire the shifter to the neutral switch and adjust it?
On the driver's side of the shifter there is the micro switch with 4 spade connectors, I extended the wires from the switch on top of the steering column to the micro switch! I got b/u lights in rev,drive,2nd,1st, And still start"s in all gear's. Any ideas would be appreciated!!
Thank's,
Larry
LV1 is offline   Reply With Quote
Old 07-26-2009, 10:48 AM   #2
instantkevin
instantkevin's Avatar
Send a message via Yahoo to instantkevin
Re: 1979 Camaro and a B+m shifter?
you just need to lookup the shifter and make sure you have the right one. there should also be install instructions on their website. or you can call them (B&M). that micro switch is probably your neutral saftey switch.... just needs to be wired correctly.
http://www.bmracing.com/
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
instantkevin is offline   Reply With Quote
