Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-19-2009, 08:06 PM   #1
MC909
starting/coolin problem
Hi i have a 1990 Camaro RS 5.0 and when it gets hot, usually only on days in the high 80's or above, after diving it for a while and parking it, it wont start after till it cools down. it used to have this problem a while back until it just would not start anymore. so i read into it a little bit and ended up putting a resistor to bypass the vatts. its been working fine until now when its hot in California. when i turn it off and go to turn it back on it will not start, the temp gets high, the radiator hose sweels like the thermostat is not letting water in. i changed my thermostat and it still does it to me. does anybody have any suggestions on what it is? i need some help
MC909 is offline   Reply With Quote
Old 06-19-2009, 08:47 PM   #2
jason-1995fbody
jason-1995fbody's Avatar
Re: starting/coolin problem
do the fan/s work
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
jason-1995fbody is offline   Reply With Quote
Old 06-22-2009, 04:41 PM   #3
stetzz05
Send a message via AIM to stetzz05 Send a message via Yahoo to stetzz05
will it crank when you try to start it or is just a slow crank? definetely an overheating issue if hose is swollen. start with the easy stuff, take the thermo out completely,check the fan fuse,make sure fan is working. you can also test the rad pressure should be 12-15 lbs
stetzz05 is offline   Reply With Quote
