Go Back   Automotive Forums Car Chat > Dodge > Caravan | Voyager
Old 03-30-2009, 09:26 PM
Idaho_Mechanic1984 Idaho_Mechanic1984 is offline
Send a message via Yahoo to Idaho_Mechanic1984
1996 3.3L 4-Speed Major Transmission Leak Problem- Picture
I am a young mechanic and haven't had too many transmission jobs yet.
I just pulled this down to replace the front seal where the torque converter goes in because it would stream fluid from the bottom of the bell housing after being driven for 15 minutes...
Turns out I see a big gash in the side of it and am now wondering how that happened!? Any helped would be much appreciated.
It looks like it was worn from the axle side....
I am guessing I found the source of the "leak."
Has anyone seen this before and how/why it happens? It was still driveable - just happened to run out of fluid rather quickly.
Any insight would be much appreciated.
http://viewmorepics.myspace.com/inde...ageID=10562948
Should be able to see through one of these links.
http://www.myspace.com/donerightautomotive
Old 03-30-2009, 09:54 PM
Jernic Jernic is offline
Re: 1996 3.3L 4-Speed Major Transmission Leak Problem- Picture
That was caused by the differential (bearing failure). I've seen that before and the only thing you can do is buy one transmission from a wrecker. Good luck
Old 03-31-2009, 11:31 PM
troy1 troy1 is offline
AF -Advisor
They got it stuck or really like to spin the tires and sent the diff cross pin through the case not a bearing issue at all. COMMON ISSUE get used to it!
Old 04-01-2009, 12:00 AM
Thank you!! I'll let 'em know!!
-Dale
