How to check compression:
How do you check the compression on a rotary (specifically a S4 non turbo). Is it the same procedure as checking a peeston engine?
RX-7 TII |
Re: How to check compression:
It is like doing it on a piston engine. remove the spark plugs and put the compression tester where the spark plugs go
1986 Mazda RX-7 1991 Nissan 300ZX
are compression testers expensive?
1989 RX-7 TII --- Just got rebuilt and street ported RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II, 720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads HKS Blow-Off Valve, Stainless brake and clutch lines |
they can be depends on brand.
Re: Re: How to check compression:
On the rotary, you have to test 3 faces of the rotor. So if you want to know how to do the garage special compression test, here it is: Get a 20-40 dollar compression tester from Checkers/Autozone/whatever... Put it in the LEADING spark plug hole of which ever rotor you feel like testing. HOLD THE AIR RELIEF VALVE DOWN!!! Watch the pulses on the gauge... That gives you a GENERAL idea of what your motor is doing.. Pulses should be 90 or higher and ALL EVEN... Rat
1988 10th AE Edition TII More mods then you have. |
Good sheezl. Thanks J Rat.
RX-7 TII |
No problem...
Please elaborate on the "pulse". what exactky should i be looking for and what numbers should the pulse range in?
with piston engines, compression is checked at tdc. what about rotors? thanks! |
