Go Back   Automotive Forums .com Car Chat > Buick > LeSabre
Old 04-15-2009, 07:52 PM   #1
johnnydoughey
Le Sabre Electrical problems
I have a 2005 Le Sabre and while driving, the tach, mileage, and dash lights flashed on and off. The speedometer, gas, and temperature needles are now cycling on and off (you can hear a scraping sound as this occurs) for a couple of minutes after starting... then work properly.
Any suggestions?
johnnydoughey is offline   Reply With Quote
Old 04-15-2009, 08:26 PM   #2
maxwedge
A990 racer
Re: Le Sabre Electrical problems
Check this link, this may be your problem. http://arrc.epnet.com.oh0049.oplin.o...sp/framerq.asp
Old 04-16-2009, 09:24 AM   #3
imidazol97
AF -Advisor
There's a problem with the link. It goes to OPLIN network of library databases for Ohio users. Once logged in , there is no link chosen; it is at a list of various databases from which to choose.
Can you give more explicit info about which base and where to see what you're wanting to show?
Your location shows New York, so I wonder how you ended up on an Ohio user library database?
imidazol97 is offline   Reply With Quote
Old 04-16-2009, 04:47 PM   #4
maxwedge
A990 racer
Long story on my access to the Oplin set up, anyway it refers to erratic gage readings and noises from the gages and involves replacing the inst cluster. All the grounds in that circuit should be checked first, though.
