Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Silverado
Old 02-25-2009, 08:08 AM   #1
ColoradoSilverado
Wheel bearing going ?
I have this sound which seems to be coming from the front wheel(s). Hard to describe the sound but I would guess a wheel bearing, truck is at 177,000 miles now. I jacked it up and rotated the front wheels but couldn't hear/feel anything unusual. What's the best way to find out if the wheel bearing is bad ?
Bert
2000 1500 Z71, 5.3 ext. cab, long bed.
ColoradoSilverado is offline   Reply With Quote
Old 02-25-2009, 09:25 AM   #2
tempfixit
Re: Wheel bearing going ?
Do you notice a change in sound when during a corner? If so, when you turn left the right wheel bearing bears the load and vice versa.
You could jack front end , remove wheel, caliper and rotor to see if you have any play when you try moving the hub by placing hands at 12 oclock and 6 oclock and see if you have any movement in bearing and turn hub slowly to feel for rough spots.
Hope this helps
tempfixit is offline   Reply With Quote
Old 02-25-2009, 10:02 AM   #3
j cAT
because of the design used in this vehicle any wheel bearing failure will cause abs/braking problems very quickly.....
since you also have leaking front dif problems of an unknown amount... I would say the front dif may be damaged and need be overhauled /replaced
Old 02-25-2009, 06:36 PM   #4
ColoradoSilverado
Hope this helps
Will try that tomorrow, I'll let you know how or what.
Bert
My Truck:
2000 Silverado,, Z71
5.3 Ext. Cab, Long Bed
Original motor + transmission!
As of 3/21/14, I'm at 266,300+ miles!
My wife's Truck:
2005 F150 Lariat CrewCab
(Way nicer them my truck!)
Old 02-25-2009, 09:32 PM   #5
sierra99
I have a 99 silverado z71 ext and had a whining sound from my front end at 35 mph and up. Turning left to right had no effect on the sound or pitch. I also had a leaky drivers side differential seal. When I replaced the front driver seal, I pulled the caliper and then turned the wheel bearing. I also went to the auto parts store beforehand and tried turning the new bearing. My original bearings had a slight rubbing sound (sounded like a rubbing brake pad), there was absolutely no movement from 12 to 6 movement. I replaced both from az (Timkens) $119 a piece and there was a 100% percent improvement. They are now both replaced and no sound at all from the front. Front driver seal was pretty easy to replace also. I would do both while I had the truck torn down to that point. Just my 2 cents. Hope this helps.
sierra99 is offline   Reply With Quote
Old 02-25-2009, 09:33 PM   #6
sierra99
forgot to mention, I changed them out at 148,000 miles. Nice tuck, I have the same but a 99 and short bed.
Tell us what you found to be the problem..
Old 02-26-2009, 12:12 PM   #7
kahjdh
kahjdh's Avatar
Get up to about 35-40 mph on a OPEN road and swerve left and right. If you notice that the sound gets quieter one way more than another it will tell you what bearing is bad. They get quieter when there is a load on them so when you turn right the weight is on the left and visa versa. Post back what you find.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
kahjdh is offline   Reply With Quote
Old 02-27-2009, 10:10 PM   #8
ukrkoz
ukrkoz's Avatar
You could jack front end , remove wheel, caliper and rotor to see if you have any play when you try moving the hub by placing hands at 12 oclock and 6 o'clock and see if you have any movement in bearing and turn hub slowly to feel for rough spots.
Hope this helps
why do you need to replace wheel, and all the caboodle? simply jack the side, get your hands on 12 and six, and push/pull vigorously. if you have play or clunk, it's your bearing. If you have play or clunk with hands on 3 and 9, it's your tierods and tierod ends. GM says to replace hub with presence of ANY play in bearing.
It's roughly $170 for the hub, a large socket rented from a parts store, and about 20 minutes "on your knees" labor.
ukrkoz is offline   Reply With Quote
Old 02-28-2009, 03:19 AM   #9
J-Ri
J-Ri's Avatar
A noisy wheel bearing isn't always loose (but will usually feel rough turning it by hand), and a loose wheel bearing doesn't always make noise. The best thing to do is replace them in pairs (since they are identical left and right, and have very close to the same mileage on them). About 95% of the time, if you turn left and the noise increases, the right wheel bearing is bad (and vice-versa)
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
J-Ri is offline   Reply With Quote
