Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Off-Topic
Register FAQ Social Groups
Old 02-16-2009, 08:28 PM
ned032002's Avatar
ned032002 ned032002 is offline
Slave Cylinder spring?
I have noticed on both the old and the new slave cylinder that there is a small spring w/ a flat piece on one end. On the old slave, I didn't see where it came from because I found it on the floor. Now I thought that maybe it didn't come from the slave so I thought of just disregarding it until I went to put the new one on and I dropped it onto the pad I was sitting on and I saw the banjo bolt fall off and the bleeder screw fall off (I didn't have them very tight, only a thread or most likely less). Now on the pad I find another one of those little springs....I have no idea where this little guy is suppose to go. I fear if I don't use it at all then I may regret it. I can take a picture for you guys if this spring doesn't ring a bell to anyone. I plan to put this back together tomorrow night so ASAP if possible. Thanks again guys.
Old 02-16-2009, 10:02 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Slave Cylinder spring?
Are you talkin about the tiny spring with a small hole in the end of it? Sounds like the restrictor that tries to help slow the release down if you pop the clutch. It suppose to help keep the car shifting smooth and what not. I took mine out and actually got less clutch chatter. This was with an aftermarket clutch though. You dont need it.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-16-2009, 10:23 PM
ned032002's Avatar
Mines an aftermarket too, ACT 2600.
Heres a pic
How does the spring go back in? What does the plate on the spring need to be touching?
Old 02-16-2009, 10:47 PM
Holset powered 420a
The spring goes infront of the banjo bolt. The plate going in 1st if I remember right. I wouldn't put it back in though.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-16-2009, 11:02 PM
ned032002's Avatar
What will happen if I don't? What will the difference be?
Old 02-17-2009, 01:19 AM
steviek's Avatar
steviek steviek is offline
Heres a pic
Ned without that spring you're car is liable to fall apart at any second most valuable component of your car right there
haha
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 02-17-2009, 07:58 AM
Holset powered 420a
The plate is a restrictor to slow the clutch fluid down if you release the clutch to quickly to keep the car from jerking and engaging smoothly.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-17-2009, 09:45 PM
ned032002's Avatar
I don't need this abuse...
I just didn't want to mess it up. I just kept thinking...how much harm can this little spring do? I just didn't know where it came from, I guess that was my biggest concern. Yeah it's not going back in.
Old 02-18-2009, 12:35 PM
steviek's Avatar
haha man i was only kidding i get that same feeling whenever I do something on the car i always end up with these WTF bolts that donm't seem to go back anywhere
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 02-18-2009, 12:43 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
I took mine out quite some time ago, way before I got the new tranny. It's always been jerky when shifting and never really though about that spring. I kind of want to put it back in (if I can find it) and see what difference is between the 2. I have bad chatter since I got this new clutch.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-18-2009, 12:51 PM
Holset powered 420a
Thats odd, mine car drives smoother this it out. I guess it depends on the clutch setup
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-19-2009, 10:33 PM
ned032002's Avatar
I think I still have it lying around if you want it Dave?
Old 02-20-2009, 12:28 AM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Its a good bet that its different since the trannies in your cars are different.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 02-20-2009, 12:51 AM
david-b's Avatar
Dave is THAT guy
No dude I'm good. Thanks though.
75 Monte Carlo
