Go Back   Automotive Forums .com Car Chat > Buick > Park Avenue
Old 08-13-2013, 10:47 PM   #1
antbella
sensors?
help please what is a pedal position senor?
antbella is offline   Reply With Quote
Old 08-14-2013, 06:22 AM   #2
SleepyHead98
SleepyHead98's Avatar
Re: sensors?
sounds like a brake related sensor, that senses if the brakes are being pressed by the driver or not/ which will cause the brake lights to come on in the back when the peddle is pressed.
"He who makes a beast out of himself gets rid of the pain of being a man."---Dr Samuel Johnson
SleepyHead98 is offline   Reply With Quote
Old 08-14-2013, 09:43 AM   #3
maxwedge
A990 racer
Re: sensors?
How about what year this is, there is no pedal position sensor other than the throttle position sensor , post back when you have the proper terminology of what you are looking for.
Old 08-14-2013, 12:34 PM   #4
Tech II
Re: sensors?
APS, or accelerator pedal sensor, is used in electronic throttle systems(also known as drive by wire throttle systems), in other words, systems that don't use a cable between the pedal and the throttle body....in GM cars, this is known as TAC, or throttle actuator control....the APS sends a signal to the PCM and the TAC module, which electrically controls a motor on the throttle plate......so the throttle plate is electrically moved, rather than by a cable from the accelerator pedal....
I'm sure everyone remembers the massive recall that Toyota had on their gas pedals, which included GM's Pontiac Vibe, a joint venture with Toyota....
Old 08-14-2013, 03:00 PM   #5
maxwedge
A990 racer
Re: sensors?
Correct on the pedal sensor /drive by wire, correct me if I am wrong here but I do not believe at the end of the Park Ave run these were implemented and it was still a cable connection throttle.
Old 08-14-2013, 10:19 PM   #6
Tech II
Re: sensors?
I was only answering his question, Max....
As for whether this system was used on the last PA's, I'm not sure....
Old 08-15-2013, 09:37 AM   #7
maxwedge
A990 racer
Re: sensors?
Yeh, lots of guesswork as usual on our part with insufficient info from the OP's.
